What brakes are cheapest but best upgrade?
Cheapest option would be to get a set of 05+ OEM brakes. The rotors are larger than yours, the calipers are larger with the fronts having 2 pistons, and the pad don't create mountains of dust like yours do. They're a direct bolt on upgrade, although you do have to cut back part of the dust shield to make the rotor fit.
Another option is this one: http://www.racingbrake.com/One_piece_Rotors_s/3359.htm. You can get this for front and rear, and down the road upgrade the calipers. It's not cheap, but it's cheaper than a full blown BBK setup, and you can upgrade in stages with it.
If you're not looking for heavy track use, the 05+ OEMs will be your best upgrade for the price.
If you have serious road race / autocross aspirations, save up for the BBKs or other, expensive ones. If you're just looking for something safer, and less dusty for on-road, save your money and just go OEM.
Don't expect significant WOAH factor when stepping up to the 05+ Brakes. IIRC, performance testing was about the same with the 03-04 and 05+ brakes.
Difference would be with fade and consistancy since the 05+ rotors are bigger and the dual piston caliper spread the clamp force out.
Red Card Crew
But the important part is the fact that you still get the world class 60-0 w/o the massive dust and rotor wear when going to the 05+ non awd brake setup.
