Is there a DIY video or write up on a coupe midpipe install?
Old Nov 30, 2009 | 02:08 PM
azt108's Avatar
Or is it as simple as removing bolts and putting them back on? I will be doing it this weekend, and I'll take some video of the sound clip before and after.
Thanks!
Old Nov 30, 2009 | 03:12 PM
SxExCx's Avatar
thats all there is to it.
Old Nov 30, 2009 | 03:14 PM
azt108's Avatar
I replaced my muffler, and it took forever to get it done. The bolts are in such an akward position and the hangers were p!ssing me off. I hope he bolts aren't rusted in on my mid-pipe and everything goes smooth...
Old Nov 30, 2009 | 03:21 PM
twin001's Avatar
usually the nuts that connect the midpipe to the y-pipe are rusted on. I just finished installing a Nismo exhaust on a friends Z this weekend and I had to use a cutoff wheel on both of them. I was able to get one of mine off on my car, the other had to be cut off. The bolts are press fit in the y-pipe flange, so if you need to cut them off just get a punch and pop out the press fit bolts and replace with a regular bolt.
Old Nov 30, 2009 | 03:35 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
It's much easier to drop the hangars from the body with the exhaust.
...then remove them.
The rest is just re & re.
Your biggest problem will be rusted nuts.
I would recommend picking up some new ones for re-assembly.
& a few bolts if you have to chop them off.
It's better to have them on hand before you start.
Old Nov 30, 2009 | 03:51 PM
Swivel's Avatar
Moderator
LOL @ 'rusted nuts' but I will refrain from comment (just this once)
Hit 'em with lots of this first (rather than a multi-purpose lube/penetrant like WD40):
Old Nov 30, 2009 | 03:53 PM
jayk's Avatar
PB Blaster for rusted bolts... let them soak... then you're Golden!
Old Nov 30, 2009 | 03:55 PM
InTgr8r's Avatar
http://www.arro.ie/HOW44014.jpg
Do tell, what's YOUR problem with rusted nuts?
Old Nov 30, 2009 | 05:15 PM
XDR-V35's Avatar
PB Blaster is the best penetrating spray you can buy, when it comes to cars.. You live in NY so rust will be your biggest problem, spray PB Blaster on all the nuts and bolts, let it sit and spray some more.. Being that I'm in Florida mine was fairly easy to take off, sprayed it, waited 5 min and used an impac gun and came right off, to get on some at the y-pipe you may need a universal.
Old Nov 30, 2009 | 05:24 PM
Mustang5L5's Avatar
Start soaking it in PB blaster days before you attempt. Just lean under the car, spray and walk away. Later on come back and spray again. Do it a few times a couple days before and then have at it.
But since it's exhaust, have a back-up plan if you snap bolts or nuts...always happens.
Old Nov 30, 2009 | 06:33 PM
SVTCOBRA's Avatar
PB blaster!
My coupe mid-pipe rubbed the cross-bar that is there to catch the driver shaft if it separates.....I removed it and no more rub.
(This was on the 05 Sedan that I traded for my 04 Coupe.)
Coupe mid-pipe is bent slightly different that the Sedan mid-pipe.
I also replaced the front gasket and re-used the doughnut.
Old Nov 30, 2009 | 08:57 PM
Blue Dream's Avatar
I drove ttrank's car solo
haha by talking about nuts and penetrant in the same post you might as well add the NSFW tag.
Sorry, I didn't have the restraint you did!!
Old Dec 2, 2009 | 03:09 PM
snotf's Avatar
COME ON. you're in the 'chu, be serious. PB blaster? i didn't get under the car without the cutoff wheel. maybe in the midwest... but i've seen an Iowa winter, so i really doubt it's much better.
EnCr1pt3d
Jul 8, 2019 02:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
lemmy999
Jul 25, 2015 12:13 PM
