Hiiiiiiiiiiiigh Pitch Squealing!!!!!
Old Dec 9, 2009 | 02:27 AM
DPeazy's Avatar
I'm living in the Cold Tundra of the T-Dot(Toronto)
This week I've been starting my G 03 Sedan and a Crazzzzzzzy
High Pitch Squealing sound terrorizes my ears....
It's sound like a Belt Sound....
I need help
Any Clue on what it could be?
Thanks
DPG35
Old Dec 9, 2009 | 04:31 AM
psedog's Avatar
Back in SD**
It could be your tensioner pulley as well. Mine had a crazy squeal for a while. I kept adjusting my pulley to no avail. Finally I replaced my A/C tensioner pulley and all was well.
Old Dec 9, 2009 | 11:42 AM
Jeff92se's Avatar
Red Card Crew
Ugh I have this too. I guess I'll loosen the belt and see how that pulley is doing. But it does stop after about 5 seconds.
Old Dec 9, 2009 | 11:50 AM
G35Papa's Avatar
It might just be a loose belt. Try tightening them up first
Old Dec 9, 2009 | 12:43 PM
Tollboothwilley's Avatar
Try tightening up the belt first.
My pulley (AC) went out and took the brand new belt with it and it was exibiting the same symptoms. But, I've had the same belt do that after I replaced it when the weather started getting cold.
Old Dec 9, 2009 | 01:28 PM
azt108's Avatar
That happened to me before. Then I remembered that I left my cat under the hood that day while changing my oil.
Old Dec 9, 2009 | 03:02 PM
g35freak86's Avatar
as others have said, try tightening up the belts first. mine used to do this back in the day. the squeel still persisted mainly in cold and wet weather. However, I got all the pulleys and belts replaced and it cured it all.
Old Dec 9, 2009 | 03:16 PM
5150DS's Avatar
It could be your neighbor screwing a pig. Just a thought.
Old Dec 9, 2009 | 03:29 PM
Wannabe6MT's Avatar
-MN G Crew-
All our cars do this in the cold..
Old Dec 9, 2009 | 08:38 PM
^^^ mine doesn't do this in the cold anymore
Old Dec 10, 2009 | 12:38 AM
AARONHL's Avatar
Your belt is loose. If you think it's tight it's not tight enough...
/thread
Old Dec 10, 2009 | 11:00 AM
psedog's Avatar
Back in SD**
I disagree. Mine doesn't do it anymore and it didn't do it before my belt snapped when I hit 30k. After changing the belt, I think I screwed up the tensioner somehow. After I replaced the tensioner all was well. Haven't had a squeal since
Old Dec 10, 2009 | 11:37 AM
Jeff92se's Avatar
Red Card Crew
Mine did it when the car was cold since the temps dropped below freezing (into the teens). So I braved the cold last night and tightened both belts. They were a bit loose anyway.
This morning? No oink
Old Dec 10, 2009 | 02:43 PM
OCG35's Avatar
its probably a small child stuck between the belly panel and the bottom of engine.
*Edit... that was in poor taste.
More likely a stuck cat.
Old Dec 10, 2009 | 09:58 PM
psedog's Avatar
Back in SD**
magnetism80
Feb 1, 2019 10:00 AM
3000vr4tt
Sep 7, 2015 12:48 AM
G35CO
Aug 25, 2015 02:00 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
