Wheels and Offset Question
Old Dec 29, 2009 | 08:47 PM
jimmykce1's Avatar
I have a 2006 G35Sedan and is lowered on Tein S-Techs (2" front and 1.5" Rear). Looking to get Axis/EXE wheels 19x8.5 wheels with 225/40/19 tires for front and 19x9.5 wheels with 255/35/19 tires for rear. The front offset will be 35 and rear will be 40. Will I need to get my rear fenders rolled?
Old Dec 29, 2009 | 09:16 PM
Texasscout's Avatar
I'm running 19 by 8" with a 30 offset. Tires are 245 40 19 Goodyear GT's
In the back, you can just get a pencil between the tire and the unrolled fender. In the front it has a bit more clearance as the front fenders are about half rolled from the factory.
Old Dec 30, 2009 | 06:15 AM
jimmykce1's Avatar
Your running a more aggressive offset, I am thinking I would be okay since the stock offsets are 45.
Old Dec 30, 2009 | 09:29 AM
FlyingLumpia's Avatar
you are also running a 1.5 wider which is 37mm more but take aways 10mm for the offset you are still about an inch more wider than him. I would just roll your fender to be safe.
Old Dec 30, 2009 | 11:52 AM
davmac's Avatar
With 9.5 in wheel width and +40mm offset the wheel is sticking out by an additional 1.45" compared to OEM 7 in and +45mm offset. All you can do is measure and try, but probably will need to roll the rear fender.
Old Dec 30, 2009 | 02:26 PM
jimmykce1's Avatar
I can go with this same wheel and run 19x8.5 all around with either a +35 or +45 offset. So I guess it will be better to run the +45 offset.
Old Dec 31, 2009 | 12:04 AM
davmac's Avatar
Actually +35 offset would work better for the front. Problem is you're running a wider wheel / tire and will interfere with the strut and suspension components in the front if you put more than ~145mm behind the hub (toward the center of the car). There's no rolling the suspension components. I know this because I used a 7 in wide wheel with +55mm offset for some snows and I barely cleared the suspension components in front.
OEM:
7 in wheel, +45mm offset = 133.9mm behind hub, 43.9mm in front of hub
Options:
8.5 in wheel +35mm offset = 142.95mm behind hub, 72.95 in front of hub
8.5 in wheel +45mm offset = 152.95mm behind hub, 62.95 in front of hub
Anything wider than a 225 tire adds to both dimensions because it would be wider than OEM. 225 tire theoretically is 8.8 in wide across the tread (tire width / 25.4).
Old Dec 31, 2009 | 01:03 AM
why dont you just roll your fender so you dont have to worry about it.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Soumilg
Jul 18, 2015 12:33 PM
