Fuel Cutting Off at Certin RPMs
Old Jan 30, 2010 | 10:32 AM
jimmykce1's Avatar
I am having problems with my 2006 AT G sedan. When you get on the gas, let off the gas, and punch the gas the car shuts down like your bouncing off the rev limiter, but its not near the red line.
My shop has replaced the mass air flow sensor and the crank position sensor. They also looked at cam sensors. The car did run better after the mass air flow sensor was replaced but the next morning it stated acting up again. Any suggestions that I can give my mechanic. They have check the throttle body and also reset the computer.
Old Jan 30, 2010 | 10:50 AM
jimmyfogg's Avatar
Did you by chance put any fuel line injector cleaner in your tank?
I ask because I put a bottle in a 3/4 full tank, and my car WOULD NOT rev over 2000rpm... stopping at a gas station and filling the tank the rest of the way solved the problem.
Old Jan 30, 2010 | 11:46 AM
jimmykce1's Avatar
No I didn't but I may have gotten some bad gas.
Old Jan 30, 2010 | 12:55 PM
maciejk's Avatar
try turning off your VDC
Old Jan 30, 2010 | 01:12 PM
ttrank's Avatar
Grocery getter
May be VDC as said above. Could also be bad gas or a partly clogged injector.
Old Jan 30, 2010 | 03:59 PM
DaveB's Avatar
Is the shop a Nissan shop?
Old Jan 30, 2010 | 07:35 PM
jimmykce1's Avatar
Its at a performance shop.
Old Jan 30, 2010 | 07:38 PM
jimmykce1's Avatar
Is there something to fix on the VDC?
Old Feb 2, 2010 | 05:01 PM
jimmykce1's Avatar
Nope...the guy working on my car checked all these things out. The computer isn't throwing a code, but the car still shuts the fuel down. The mechanic thinks there is an electrical problem somewhere. I hope he finds it soon.
Old Feb 3, 2010 | 12:28 PM
jimmykce1's Avatar
The guy working on my car said that my car shuts down the fuel/engine when you turn. This does it with and without the VDC on. Anyone has had or heard about this problem before.
Old Feb 3, 2010 | 02:07 PM
azt108's Avatar
wtf????
Old Feb 3, 2010 | 03:38 PM
Tollboothwilley's Avatar
i've had my VDC off and it cut fuel because it slips. "SLIP" light should show up for half a sec if that is the case. This is due to #1) open diff #2) traction #3) electronic limited slip braking, all of which play a factor but the major part is the braking system.
You could unplug your YAW sensor and take it for a spin, see if it solves your problem.
Old Feb 3, 2010 | 05:27 PM
DaveB's Avatar
Take it to a Nissan shop. You're going to be wasting a lot of time and money having someone at a performance shop trying to guess what the problem is and randomly replacing parts. A Nissan/Infiniti tech will use a Consult computer to trouble shoot the car and will find the source of the problem far quicker. The Consult computer can very sensor value on the car.
It sounds to me that there's a problem with the steering wheel position sensor which is connected to the VDC system. This problem is over your techs head.
Old Feb 4, 2010 | 09:05 AM
jimmykce1's Avatar
Car is fixed!!! The crank postion sensor that he replaced was bad, so he got another one and the solved the whole problem. I got the mass air flow sensor replaced, cam sensors, and crank position sensor. Thanks for all the suggestion and imput from everyone.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Hogbone
Sep 28, 2015 06:44 PM
vamarris
Sep 26, 2015 12:56 PM
