oil pressure gauge
Old Apr 12, 2010 | 04:26 PM
oscar_g-sedan06's Avatar
oil pressure gauge
u think if i put a oil pressure gauge it would help me out when need to add oil??because i add 1 quart every 1500 miles?? or anything else i can do to remind me or help out
Old Apr 12, 2010 | 04:50 PM
H0TEP's Avatar
Do you have Navi? I set the maintenance reminder for 3000 miles so when that time comes the navi will alert me that it's time to change the oil and/or filter.
Old Apr 12, 2010 | 04:52 PM
OKStateG35's Avatar
I don't think oil pressure gauges show you the level of your oil, just that whatever oil you have left is running at the correct pressure. Just check it every thousand miles or so. Takes 30 seconds to do.
Old Apr 12, 2010 | 05:17 PM
H0TEP's Avatar
Or set a reminder on your phone?
Old Apr 12, 2010 | 07:20 PM
Mustang5L5's Avatar
No, an oil pressure gaune won't tell you when you're oil is low.
You'd have to get a low oil level switch, and drill and tap the oil pan. When you run low, the switch opens and an LED will light up alerting you to low oil. All this is custom though...no kits for that but if you know wiring it can be done easily if you want to pull your pan off.
If you are using oil...get in the habit of checking your oil level every time you go to the gas station. Or hit the trip reset button and let it count to 1500...we do have two tripometers. There's no easier way that that.
Old Apr 12, 2010 | 07:35 PM
thescreensavers's Avatar
Mr.202?
Not on the VQ
Old Apr 12, 2010 | 07:40 PM
gary c's Avatar
Oil gauges show pressure not levels, rather than spend $ on something you probably won't use anyway check your oil level weekly via the dip stick.
Gary
Old Apr 12, 2010 | 08:04 PM
thankx for the info guy's ill guess ill keep checking it every friday morning thankx...
Old Apr 13, 2010 | 09:19 AM
OKStateG35's Avatar
Originally Posted by thescreensavers
[/B]
Not on the VQ
Haha, true. That dipstick sucks. It only takes me a second though as long as I have a light so I can see what I'm doing.
Old Apr 13, 2010 | 12:04 PM
eleeksta's Avatar
Do you punch the gas a lot and reach high RPM? Could be burning some oil up if that's happening. I know i am guilty of that, and need to add a little oil between changes. Also, i think using different weights of oil could cause problems such as this, so make sure to always use the weight specified--no matter the season.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
yosip1115
16
Sep 28, 2015 04:14 PM
JustinMKN1
Sep 18, 2015 03:40 PM
