04 G35X Rear Knuckle bushings
Old Apr 15, 2010 | 10:28 PM
Cardinal's Avatar
I need to replace the rear knuckle bushings for an 04 AWD, I contacted some dealerships that stated you need to buy new knuckles. I don't want to buy two new rear knuckles just to replace the bushings. I found after market bushings (Whiteline) for coupes. Can anyone advise if the rear hub bushings are the same for the X? Vendor is not sure if application is the same.
Old Apr 20, 2010 | 10:14 PM
dfaulk3's Avatar
How do you know when these are going out? Do they make a noise? Where are they located? I have a noise coming from teh rear of my car and im trying to figure out what it is.
Old Apr 20, 2010 | 10:44 PM
Cardinal's Avatar
I was replacing the rear shocks and springs and the shock mount bushing tore. I decided to replace all the bushing on each of the knuckles since I was taking them off anyway. Noise from the rear is to general to give you an answer. If you lowered the car, maybe the endlink?
Old Apr 20, 2010 | 10:45 PM
dfaulk3's Avatar
Its not lowered and I typically hear the noise coming from the back of the car when im turning.
Old Apr 20, 2010 | 11:03 PM
Cardinal's Avatar
Start with the easy stuff first before dismantling the rear end. Is it a growl like road noise or a clunking. When did you first notice it? Shortly after a pot hole? Check the rear brakes. Did you change wheel size in the rear? Clearance Issue? Check rear fender lining for loose clips. Then move on to hardware parts like wheel bearings,shocks etc.. You can always check the NVH sections in the service manual.
Old Apr 20, 2010 | 11:11 PM
dfaulk3's Avatar
Its definitely a clunking sound its really annoying.
Old Apr 20, 2010 | 11:29 PM
Cardinal's Avatar
Sounds silly but do you have anything rolling around the trunk. Maybe the muffler hanger tore? Try putting someone in the backseat to isolate where the sound is coming from. Rear shocks upper mounts are right behind the rear seats. Check the simple stuff first, then move on. Check the brakes,then the rear end links, wheel bearings,shocks.
Check mounting locations for looseness.
Old Apr 21, 2010 | 10:04 AM
OKStateG35's Avatar
I think Whiteline makes replacement bushings for pretty much everything in the front and rear of Sedans. I was reading this thread the other day and there is a link to a Vendor who sells various kits.
https://g35driver.com/forums/brakes-...-replaced.html
Old Apr 23, 2010 | 09:54 AM
Cardinal's Avatar
Thanks for the info, I placed an order for these several days ago and waiting for the shipment same vendor. I post if these fit the x after the install.
Old Apr 23, 2010 | 10:19 AM
OKStateG35's Avatar
Definitely let us know how it goes. I'll probably order some of these as my bushings start to fail.
rezendvous420
May 31, 2020 01:26 PM
si_driver
Aug 11, 2015 07:08 AM
atk08
Jul 30, 2015 03:12 PM
DarkLyter
Jul 28, 2015 04:57 PM
teamghost
Jul 28, 2015 04:52 PM
