Burnt out HID
Old May 13, 2010 | 06:05 PM
herolad's Avatar
Burnt out HID
So I just took my 05 g35 sedan to the dealership and they told me that my HID light and ballast needs to be replace and it would cost 600ish dollars. Can I do this myself by just buying a HID kit that includes the ballast and replace it myself? I see this post here (https://g35driver.com/forums/body-int...hid-bulbs.html) shows how you can replace the bulb but will you have access to the ballast to replace it to? Any good suggestions on where I can get a good kit?
Thanks.
Old May 13, 2010 | 06:45 PM
Nyteowl's Avatar
Have you tried to replace the bulb to see if it works?
Old May 13, 2010 | 06:50 PM
dsmmyth's Avatar
Try getting a new pair of bulbs first. They're easy to replace.
Disconnect battery. Just jack it up, remove the wheel, and remove the panel. Replace.
Old May 13, 2010 | 07:22 PM
thescreensavers's Avatar
Mr.202?
Check out http://www.ddmtuning.com/
They got bulbs and ballasts with lifetime warranty.
Old May 13, 2010 | 08:20 PM
r1forever80's Avatar
If you have a circuit tester check to make sure you are getting power to the ballast first and if you are check the igniter which is the part that attaches to the bulb. If you are then switch bulbs from the other light to make sure its not a bad bulb. No point in buying stuff you dont need. check fuses and what not first
Old May 13, 2010 | 09:25 PM
Ludafish's Avatar
OH NO! It sounds like another attack from the stealership...Def check the cheapest route (bulb) first...GL
Old May 14, 2010 | 12:35 AM
olopez's Avatar
I have a set of OEM bulbs I'm selling cheap! PM me
Old May 14, 2010 | 12:51 AM
erklep's Avatar
and i have a set of ballasts that id sell you.
Old May 14, 2010 | 10:28 PM
pwebb's Avatar
you could try swapping bulbs and see if they problem switches with it...
you can then decide if you need just bulbs or a ballast.
Old May 24, 2010 | 08:31 PM
BulletG35's Avatar
Originally Posted by herolad
So I just took my 05 g35 sedan to the dealership and they told me that my hid light kits and ballast needs to be replace and it would cost 600ish dollars. Can I do this myself by just buying a hid kits that includes the ballast and replace it myself? I see this post here shows how you can replace the bulb but will you have access to the ballast to replace it to? Any good suggestions on where I can get a good kit?
Thanks.
Replacing the bulb will be a cheaper way to go and see if everything is fine.
Old May 24, 2010 | 08:36 PM
s2jeezy's Avatar
$600 is insane. like everyone else says check the bulb first, you can always buy oem on here for cheap.
Old May 25, 2010 | 08:51 AM
blazeplacid's Avatar
swap whatever bulb is it with the other side....
Old May 28, 2010 | 08:46 PM
CBRworm's Avatar
20 Year Member
My ballast just stopped working on the left side. Blows the fuse as soon as the lights are turned on.
FYI the fuse is in the 'intelligent power module' under the windshield behind the battery.
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
MrIP35
Oct 25, 2015 11:13 PM
twentyeggs
Sep 11, 2015 03:58 PM
