Pass window goes up and then goes down 1/4 again?
Old May 17, 2010 | 02:50 PM
Jeff92se's Avatar
Red Card Crew
When using the auto up feature, the window will go up and then go back down about 1/4 of the way. What is that and how to fix?
Old May 17, 2010 | 05:45 PM
Jeff92se's Avatar
Red Card Crew
Needs a window reset?
Power Window Reset Procedure
1. Remove the Door Panel. 2003-2005 Front Door Panel Removal Procedure
1. Remove door panel.
a) Remove screw at door open pull.
b) Remove door handle trim, pry silver plastic trim piece from lower side
with a screwdriver. There's a small notch for the screwdriver blade to
fit in. remove the two screws behind this cover.
c) Lift window switch plate up from the front edge it just pops off.
Unplug wire harness.
d) Pull door panel off, clips hold it on, start from the lower edge.
e) Remove door lock and handle rods from the levers.
f) Unplug courtesy light at bottom of door.
2. With the door open, lift UP and HOLD the Window Switch until the Window is fully closed.
• Do not use the Window auto-closing function
• Do not release the Switch before the Window is fully closed
3. Get inside the vehicle and close the door.
• You need to close the door so the Door Switch is fully depressed
4. Press and HOLD the Window Regulator Motor Reset Switch. While holding the Reset Switch, press DOWN and HOLD the Window Switch until the Window is fully opened.
• Do not use the Window auto-opening function
• Do not release the Switch before the Window is fully opened
5. Release the Reset Switch. Then, lift UP and HOLD the Window Switch until the Window is fully closed.
6. Open the Door to release the Door Switch. The Window Glass should partially move down.
7. Re-install the Door Panel.
Old May 17, 2010 | 07:05 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
orr check the rubber thing to make sure that its not blocking the window that was my problem, i just shifted it around and that fixed it
Old May 17, 2010 | 07:47 PM
Heist.'s Avatar
something is blocking the window or it needs reset. Both my fronts do it. i love it. haha. 99% positive you just need to reset it.
Old May 17, 2010 | 07:49 PM
NFSP G35's Avatar
? = 2B || !2B
I would say window reset. I've heard of them doing something similar and a window reset fixed it.
It's a good place to start anyway.
Old May 17, 2010 | 09:28 PM
bag35's Avatar
my passenger window started doing that, reseted it and it worked for a little bit. it started doing it again and i made sure nothing was interfering. just decided to replace the motor and i has been working perfect. i guess i can just start acting up if the motor starts to go out.
Old May 18, 2010 | 06:00 PM
Choleaoum's Avatar
My car did this when I first bought it, I thought it was like some cool JDM feature lol. Then I realize that it got annoying and I needed to reset my window. It's really easy just take off your door panel and find this black sticker take it off and push the button. I was an idiot and didn't read the directions all the way and made my job harder then it should have been. (I tried to get to the button and didn't realize that it was a sticker in front of it that I could have easily moved)
Old May 18, 2010 | 10:03 PM
G35fromTO's Avatar
My front driver window does it. The reset didn't work for me so it's either the motor or the window's position is slightly off on the rail and needs to be adjusted. I've let it be for the last year but maybe will try to fix it this summer; I just hate taking off panels cause of those clips!
Old May 19, 2010 | 12:02 AM
Tangerine's Avatar
Apparently a common issue (according to this forum and the dealership). Reset is only a temp fix, you should also clean the motors while the panels are out. If that doesn't work, then it is suggested to replace the window modules and worst case scenario the BCM.
Old May 19, 2010 | 10:55 AM
Swivel's Avatar
Moderator
Did you ever get this fixed?
Old May 19, 2010 | 11:58 AM
Jeff92se's Avatar
Red Card Crew
Not yet.
Old May 19, 2010 | 12:49 PM
Choleaoum's Avatar
really? it took me several tries to fix my driver window by the way.
Old May 20, 2010 | 12:46 AM
fobizzle's Avatar
mine does this too its so annoying. I guess ill try to reset it this weekend. thanks for the reset procedure
Old May 22, 2010 | 02:42 PM
paky786's Avatar
My passenger side started doing that and now the switch doesn't work at all to go up or down. When someone gets out and shuts the door, the window goes down abit and it takes forever for it to bring it back up. Do you guys think I need a new motor?
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
