Plenum Whistle
Old May 27, 2010 | 12:38 AM
ECG35's Avatar
Plenum Whistle
Just installed a 5/8 plenum spacer, and Im getting a very high pitched whistle just as the car is in idle. Any ideas? Im going to try loosening the screws might be too tight causing the spacer to warp, but suggestions are welcomed.
Anyone else run into this problem?
Old May 27, 2010 | 12:44 AM
drkay's Avatar
did you use a torque wrench? the outside bolts must be torqued to 100 ft lbs and the inside bolts must be 80 ft lbs. i think that would be the first place to start if you didn't use a torque wrench. but yeah if the bolts are too tight you will warp the spacer and get the plenum whistle
2004 G35x, Motordyne 5/16" Copper Iso Thermal Plenum Spacer, Z-Tube with Pop-Charger, NGK Iridium, Mobil 1 Synthetic, EBC Green Stuff Pads with EBC 3GD Sport Rotors, Brake Master Cylinder Stiffener, OEM Spoiler, Grounding Kit, 235/50/17
Old May 27, 2010 | 12:46 AM
TwoFiveBravo's Avatar
I had no problems with my 5/16. did you tighten them down in order? Maybe one isnt tightened?
Old May 27, 2010 | 12:49 AM
GF-4D-G35's Avatar
DO NOT torque to 100 ft lbs, it is INCH lbs and there is a specific order to do it in
http://www.motordyneengineering.com/manual.pdf
thescreensavers's Avatar
Mr.202?
^ INCH POUNDS!
Its different from foot pounds
100 inch pounds is 8.33 Foot pounds.
Old May 27, 2010 | 12:54 AM
G SEDAN's Avatar
while the other points are valid,
you probably need to get a new gasket
Old May 27, 2010 | 01:18 AM
drkay's Avatar
oh crap. . . I mis typed. . In lbs!
Old May 27, 2010 | 01:35 AM
SxExCx's Avatar
I am willing to bet that the rubber surround for the oil filler neck is wedged between the plenum and the spacer.
Old May 27, 2010 | 01:46 AM
Tollboothwilley's Avatar
what plenum spacer is it?
You need to retorque the bolts down. be careful, some people have overtightened and caused much more serious problems...
Old May 27, 2010 | 07:36 AM
ccc123pm's Avatar
X
does it sound something like this?
Old May 27, 2010 | 08:11 AM
Gusc35's Avatar
lmao
Old May 27, 2010 | 09:50 AM
OKStateG35's Avatar
http://www.youtube.com/watch?v=n79jSzKA0L8
I can't watch YouTube videos at work, but please tell me that is the whistling muffler tips video with Bub Rub and Lil' Sis.
It's like an alarm clock...woo wooooo!
Old May 27, 2010 | 10:16 AM
GThirty-Kevin's Avatar
^ Haha, I love that video! The best is when he almost drills a stop sign and a parked car while trying to show off by speeding away at the end.
"Iss only in da moaning, you should be up cooking brefass o' somethin'."
Old May 27, 2010 | 10:26 AM
OKStateG35's Avatar
Haha, I was just recently introduced to it's greatness by my wife. I love it.
Old May 27, 2010 | 10:57 AM
After seeing that video it totally makes me want to get one of those whistle tips. Only two problems:
1. Only available in Oakland
2. Hurts performance because "Iss juss fo' decoration"
