issue regarding offset on g37 rims
Old Jun 8, 2010 | 02:28 AM
socialconflicts's Avatar
i have some g37 coupe rims, the offset is completely weird, something i didnt expect and im wondering what the problems could be
front specs are 19-8.5 +43
Rear specs are 19- 9 +30
with the rear offset being 30, would that mean they would stick out or does it mean i would need spacers to make them fit flush?
Old Jun 8, 2010 | 02:34 AM
geesahtee5's Avatar
at that width and offset and ur z drop, it should sit nice and flush..
Old Jun 8, 2010 | 02:35 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
They'll be fine with your suspension. They'll stick out a half inch more than your coupe 18's do now.
-GP-
Old Jun 8, 2010 | 02:41 AM
-GP-
i was worried it wouldnt fit at all because the high difference in offset,
43 being front and 30 being rear..
Old Jun 8, 2010 | 02:42 AM
doesnt matter. My front is at +5 and rear is at +20. You'll need a spacer up front to get it even close to flush, but it'll still fit.
4DGS's Avatar
What is so completely weird?
Read up on offsets I think you're a little bit confused (no offense, just from some of the questions you've been asking)
This is a petty well written explanation and can sort you through most of your confusion.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Jun 8, 2010 | 02:43 AM
i am confused..
i will read into that though for sure.
Old Jun 8, 2010 | 02:46 AM
4DGS's Avatar
Those wheels will bolt on problem free. The rear will look pretty flush and you can run a normal sized tire on it. I suggest at least a 10mm spacer for the front, but you can be the judge of how much further you want to go once the wheels are on the car.
Remember if you end up going lower you'll need to add spacers to become flush again.
Old Jun 8, 2010 | 02:50 AM
i appreciate your help, a lot
i dont know what i would do without the help of you guys, i was already freaking out lol!
thanks a lot everyone
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
paolojericho11
Sep 11, 2015 07:08 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
newg37
Jul 26, 2015 09:32 AM
