should i replace my rear brakes only.. or all
Old Jul 7, 2010 | 12:52 AM
socialconflicts's Avatar
i need to replace my brakes and was just wondering if i should replace my rears since they have 3mm left, my fronts have 7mm which doesnt seem like much either..
ima have grant do it for me and was told that i dont need to resurface my rotors if i feel they are still good and not warped. i feel them fine just figure i let ya know so you guys can give me your advice if i should just stick new pads in or have them resurfaced.
ima be putting on some akebonos since i have heard great reviews on them, biggest bang for the buck.
thanks !
Old Jul 7, 2010 | 01:11 AM
RAZ76's Avatar
I always replace all 4 at once, same with tires and same with shocks.
Old Jul 7, 2010 | 02:23 AM
DivZero's Avatar
Replacing all four ends is not necessary.
Old Jul 7, 2010 | 02:47 AM
JAYY-G35's Avatar
I changed all four!
Old Jul 7, 2010 | 03:45 AM
what about my rotors... they are not warped or at least i dont feel them warped.. should i resurface them?
Old Jul 7, 2010 | 04:01 AM
TwoFiveBravo's Avatar
I would say it depends on how soon you plan to get the BBK. I am saving for it right now also. And Grant will be doing my install haha. Why waste money on brakes now if you are going to replace them though? How soon do you plan to get the Akebonos? How much longer can yours make it?
Old Jul 7, 2010 | 04:05 AM
im not going BBK.. just the akebono pads
i was before going to install some brembos.. but decided to stay stock on my brakes for now.
Old Jul 7, 2010 | 04:09 AM
oop my fault lol. I would replace all 4 corners at the same time then. Unless money is really an issue, then do what is top priority.
Old Jul 7, 2010 | 04:16 AM
7mm isnt much left so i guess i will just replace all 4, just wondering on rotors
Old Jul 7, 2010 | 06:18 AM
Blue Dream's Avatar
I drove ttrank's car solo
I would have them turned the least amount possible. That will provide a clean surface for the new pads to adhere to. Make sure you bed in the new pads as well.
Old Jul 7, 2010 | 08:57 AM
jimNC's Avatar
My opinion - only turn the rotors when they need it. You can't turn them an unlimited number of times and if you're not having any issues, then don't turn them.
No need to do all 4 pads at once. Change the ones that are worn in pairs.
Minimum thickness on pads is 2mm all around. You've got thousands of miles left on your front pads so I would not change them at 7mm, at least not for wear. If you want to swap them all out for ceramics for less dusting, then you can certainly do that.
I've got the Akebono ProACT pads and I like them - no dusting, but they definitely do not have the stopping power of the OEMs.
The rear pads wear relatively quickly on this car - the fronts last quite a long time. You'd have those fronts for awhile if you left them on. YMMV, of course.
Old Jul 7, 2010 | 10:48 AM
RADIOGUY21's Avatar
i changed the rears on my 05 around 30K, and didnt do my fronts until 60K. I could have probably gotten another 5K out of the fronts.
rezendvous420
May 31, 2020 01:26 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
atk08
Jul 30, 2015 03:12 PM
emorehs
Jul 17, 2015 09:45 AM
nascarbuff17
Jul 16, 2015 10:23 AM
