Tire Pressure Alert
Old Jul 7, 2010 | 11:10 AM
jmcohen23's Avatar
Tire Pressure Alert
Just curious to see if anyone (particularly those currently engulfed in the heatwave - so I guess that excludes you Canadian drivers, eh?) has had their tire pressure alert light come on recently? Mine came on, and I checked all 4 tires (and the spare), and they were each set to 35lbs.... however, the lgiht continues to stay on. could this be a heat related thing?
Old Jul 7, 2010 | 11:57 AM
Bassman's Avatar
How good is your pressure gauge? I broke down and bought a calibrated guage from JEGS. Found out that the other gauges I had read low by as much as 7 psi.
Old Jul 7, 2010 | 01:23 PM
bigwilly's Avatar
Did you check the spare tire in the trunk?
Old Jul 7, 2010 | 03:34 PM
V's G's Avatar
mine does the same thing from time to time, but i haven't considered checking the spare which i'll do tonight. mine kept going off for a few weeks and each time i checked, i was around 35. it hasn't happened in a few weeks for me now.
Old Jul 7, 2010 | 06:03 PM
CG4DR's Avatar
what year is your car?
Old Jul 7, 2010 | 08:32 PM
nasman3188's Avatar
I've never had any issues here in Houston, and our temps are regularly higher than the 'heat wave' ya'll are experiencing. 35 psi seems kind of low... is that the max your tires are rated for?
Old Jul 7, 2010 | 08:38 PM
CG4DR's Avatar
35 is low? wtf are you driving?
Old Jul 7, 2010 | 10:15 PM
NAT@FFTec's Avatar
My tpms light also constantly goes on after 30+ minutes of driving. The pressure is not low for sure as I have been checking it everyday. Pressure stays at a constant 35psi. Car is an 05
Old Jul 7, 2010 | 10:20 PM
jmcohen23's Avatar
thanks for the responses ya'll.... my model year is 2005.
I did check the spare, and it was flat. I added air, but that was a week ago.
according to the manual, the alert does NOT look at the spare. however, since i bought the car used, the spare (which is a full size spare) is a different brand than my current tires. the alert has gone on before, and after refilling one of the tires, the alert turned off. but now, it won't go away.
I'm wondering if one of the sensors broke/fried.... and where exactly is the sensor on the tire?
Old Jul 7, 2010 | 10:43 PM
NAT@FFTec's Avatar
Iirc the spare does not have a tpms sensor. This shouldn't be a problem as I have not had a spare tire in my trunk for over 2 years
Old Jul 7, 2010 | 11:32 PM
NAT@FFTec's Avatar
Old Jul 8, 2010 | 02:33 AM
nasman3188's Avatar
i forget what brand but max pressure is quoted at 50 psi.
Old Jul 8, 2010 | 02:39 AM
350GT-R's Avatar
for alot of awd drivers, the spare does have a sensor. but it would not trigger anything. i have no tire pressure sensor on any of my wheels. the lights never came on at all. unless im driving about 100mph+ on a highway for about 1hr and 45minutes then the lights will go on and i pull over to the rest stop, check my pressure, it's all good, lights when off, drive again.
Old Jul 8, 2010 | 02:56 AM
4D05G35's Avatar
That is MAX pressure recommened for the tire, not the recommended operating pressure. Check your door jam and you will see the recommended tire pressure set by Infiniti. Mine shows 30psi for an 05 rwd. Now if you change your tires to a different size you can play around with the pressure (higher/lower) slightly. You never want to air your tires according to the MAX pressure on the tire sidewall.
Old Jul 8, 2010 | 08:23 AM
Bassman's Avatar
Could be that a battery in one or more of the sensors has failed.
