Wider tires on stock wheels.
Old Jul 22, 2010 | 10:51 PM
toymachine2009's Avatar
Is this true... Can you put a more aggressive offset tire like 245 or 255 on a 235 wheels?
Tires I have currently on my car are 235/35/18 dude at discount tire told me to get a more aggressive offset?
Never new you can do this.. is this true?
Old Jul 22, 2010 | 10:55 PM
Rodrigo's Avatar
you could do a 245 35 18 or 245 40 18 .
it all depends on the width of your rim . a 255 will be over kill and you will rub if your fenders are not rolled.
Old Jul 22, 2010 | 10:56 PM
SN00P's Avatar
CLUB MODERATOR
I'm assuming your stock is like a 7.5 Wide in the back and if you put a 255 in the back would make it look retarded IMO your side walls Will be blown out past the rims
Old Jul 22, 2010 | 10:57 PM
Okay I was a little confused because I thought tires can only be as wide as the rim itself.. I am not quite sure im following..
Old Jul 22, 2010 | 10:59 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You have a 235/45. You can go 245/45 or 245/40. I would do 245/45 since you're not dropped too much. It'll fill in the gap nicely.
Old Jul 22, 2010 | 11:02 PM
Cool thanks! Thanks for the fast reply.. Ill look into getting some.. I am dropped on 350z s-techs btw..
Old Jul 22, 2010 | 11:03 PM
Texasscout's Avatar
I did 245 45 18 on my stock wheels with no issues, in fact it rode and handled much better.
Old Jul 22, 2010 | 11:04 PM
SN00P's Avatar
CLUB MODERATOR
A 255/50 will work in the rear but you have to worry about rubbing.. I read that i n a post ... Try searching "biggest tire on a stock rim" and find the thread on this topic and read it
Here is the link take a look ....
https://g35driver.com/forums/wheels-...tock-rims.html
Old Jul 22, 2010 | 11:09 PM
Cool Ill probably go this route.
Old Jul 22, 2010 | 11:37 PM
I know that 245 is the width of the tire and 18 is the rim size but what's the 40?
Old Jul 22, 2010 | 11:39 PM
5150DS's Avatar
This is what I am currently running and it looks good unless you are into the stretched look.
Old Jul 22, 2010 | 11:41 PM
Pics of your setups?
Old Jul 22, 2010 | 11:50 PM
SN00P's Avatar
CLUB MODERATOR
245-width of tire , 40-Aspect ratio of the side wall (height) , 18-wheel size you have been on these forums how long now and didn't know that??? Lol
Old Jul 23, 2010 | 12:00 AM
Lol this is first time I'm buying tires so it's first time I actually have to know it.. Haha so I know I'm getting 245s now I gotta figure out if I'm low enough to run 40s or 45s
Old Jul 23, 2010 | 12:10 AM
SN00P's Avatar
CLUB MODERATOR
So your goal is what figure out tire specs for your wheels to get .... If you are low a taller tire will rub .... Post a picture of your car and tell us if you have a drop , if so how high is the fender to the floor ??? I'm assuming you want hide some wheel gaps as well ...
