intake problem. HELP
Old Jul 23, 2010 | 08:54 PM
e.c.rep35's Avatar
Exclamation intake problem. HELP
So i just recently installed a cold air intake to my 05 coupe. things were going fine until i realized that whenever i would turn my air conditioning on my idle would flucuate drastically. It got to the point where my car would stall out if i was at a stoplight. I got my car into the shop and they said they could not find anything wrong with the engine but they suspected the intake to be the problem. I assumed it would have been the maf but when i put the stock intake on once more the problem was gone. I want to put the cold air intake back on but i want to know if i can do anything to stop the problem.
Old Jul 23, 2010 | 09:05 PM
e.c.rep35's Avatar
meant to go into coupe section but whatever
Old Jul 23, 2010 | 09:10 PM
Heist.'s Avatar
make sure the intake has no leaks? Unplug the battery and let the ecu reset.
Old Jul 23, 2010 | 10:53 PM
ThePhoenix's Avatar
as Heist said disconnect the battery etc then install it, connect the battery and start it up, let it idle for a few minutes then give it some revs (dont go crazy) and the ECU should adjust itself since the ECU used in the G adjusts itself... it might just be that the battery was not removed so it never adjusted so its thinking its not getting to right A/F levels etc.
Old Jul 24, 2010 | 01:29 AM
NFSP G35's Avatar
? = 2B || !2B
Probably had a leak somewhere. The VQs really don't like un-metered air.
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
AL8782
Oct 3, 2015 10:26 AM
vamarris
Sep 26, 2015 12:56 PM
