Random Little Question Thread
Old Nov 6, 2010 | 07:32 PM
  #1666
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
This July my AT 2006 base IP sedan 37,500 miles, was marked $21,995 I brought that price down to $18,000. I don't care for the nismo body, instead I will do front and rear lips and the splash guards.
Old Nov 6, 2010 | 07:37 PM
  #1667
CandlestickPark's Avatar
ill Sedan
Originally Posted by Hammerhead i-Eagle Thrust
A. they are looking for automatic so its not a rev up
B. my 04 had the same problem when I bought it at 67,000, got a new engine I even changed the oil(which I why I stongly advocate warranties..lol)
anyways just out of err um curiosity, where would one get a nismo front bumper or high quality replica anyway?
Replica
https://g35driver.com/forums/exterio...air-ducts.html
https://g35driver.com/forums/exterio...group-buy.html
Authentic
https://g35driver.com/forums/g35-sed...-04-sedan.html
Old Nov 6, 2010 | 07:45 PM
  #1668
Hammerhead i-Eagle Thrust's Avatar
interesting... my bumper is hurting a bit, got caught on my new driveway...i dont really need to replace it though idk
Old Nov 7, 2010 | 12:10 AM
  #1669
heph's Avatar
Alignment RLQs:
Running sedan eibach pro kit, just had it aligned:
I'm picking up a rear SPC kit from Johnny Beast Foo mainly to get the rear left toe in spec and maybe even up the rear camber.
1- Would you drop the couple hundred for a front camber kit at the same time given these numbers? Front camber doesn't seem too bad, and the front left caster is just out of spec at 7.7 degrees.
2- I drive an X - anyone know which front kits do or don't fit the AWD?
Old Nov 7, 2010 | 12:30 AM
  #1670
OCG35's Avatar
^^^couple hundred for a-arms is cheap (depending on what kind)... but many of them don't have caster adjustment... what a-arms are you thinking of getting?
Old Nov 7, 2010 | 01:03 AM
  #1671
thescreensavers's Avatar
Mr.202?
Originally Posted by heph
Alignment RLQs:
I am no alignment expert but
I am pretty sure you cannot adjust camber in this car at all stock. And some how it was adjusted on your car
Rear Left Toe is way out of spec, and Thrust angle should be 0.
Old Nov 7, 2010 | 01:47 AM
  #1672
OCG35's Avatar
front no, rear slightly
Old Nov 7, 2010 | 01:12 AM
  #1673
nazc0's Avatar
2006 Vortech supercharged Sedan
the rear is adjustable to almost +/-1 degree
Old Nov 7, 2010 | 08:28 AM
  #1674
naughty240's Avatar
I was referring to me and within the 03-04 vs 05-06 posts.
Old Nov 7, 2010 | 11:19 AM
  #1675
heph's Avatar
I'm not sure I am going to get the front A-arms at this point. I'm curious as to whether people would go to the trouble for the way it sits right now, and if so what will fit the X. Maybe I should post the AWD question in the dropped X thread.
I'm open to suggestions but had looked at SPC for the front as well, which are probably close to $400 new. SPC does have caster adjustment. If I understand correctly excessive caster will make the steering less responsive, but I assume 0.3 degrees out of spec wouldn't be very noticeable.
Old Nov 7, 2010 | 12:05 PM
  #1676
OCG35's Avatar
how old are the springs? As they settle you might get a bit more neg camber... you're arent excessively out of spec, but as time goes on it might get more so... are the $200 a-arms you mentioned SPC? (used I presume)... btw, my understanding is cross caster is the important spec, and yours seems to be good.
Old Nov 7, 2010 | 02:21 PM
  #1677
OCG35's Avatar
I posted this in the "have a question about wheels" thread - no response...
Offset/Camber Gurus... do you have answer?
Current camber is -1.3 on all four... If I get wheels that are extend 10mm, how much camber do I need to be where I am now?
Specific specs:
current: 8.5 +15 (-1.3 camber) front and rear (sits 5mm inside fender line)
potential new: front 9.5 +17(extends 11mm), rear 10.5 +30 (extends 10mm)
I've never been able to confirm mm to camber ratio... I'm thinking 10mm = 1 degree (but I've read as low as 5mm = 1 degree)
If in fact its 10/1 will I now need -2.3 to sit where it is now? To add more question to the formula, I'd like to be about 3mm tucked from where I am now - so would that mean closer to -2.5 camber?... I'm calculating it as current -1.3 plus additional -1 for the added 10mm (and another couple tenths of a degree to bring it in a few more mm).
Hope the way I questioned it isnt too confusing
I'm considering a used set for sale, need to decide soon... can anyone help?
Old Nov 7, 2010 | 02:26 PM
  #1678
Swivel's Avatar
Moderator
I understand the question but don't know the answer. I suppose you could do the trig and calculate it...
  #1679
hL.'s Avatar
hL.
Will 03/04 sedan splash guards/mud flaps fit NISMO side skirts and rear valence?
Old Nov 7, 2010 | 02:30 PM
  #1680
NFSP G35's Avatar
? = 2B || !2B
^Not without modification... but it wouldn't look right anyway
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
