Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Nov 7, 2010 | 03:32 PM
  #1681
hL.'s Avatar
hL.
Originally Posted by NFSP G35
^Not without modification... but it wouldn't look right anyway
any pics with it being done?
Old Nov 7, 2010 | 10:31 PM
  #1682
heph's Avatar
Originally Posted by OCG35
how old are the springs? As they settle you might get a bit more neg camber... you're arent excessively out of spec, but as time goes on it might get more so... are the $200 a-arms you mentioned SPC? (used I presume)... btw, my understanding is cross caster is the important spec, and yours seems to be good.
Springs have been on about a month and had several hundred miles on them before I was able to have the alignment done. They seem to have settled about as much as they're going to.
No, I don't have a line on any used a-arms at the moment. I misspoke about the "couple hundred" thinking I'd seen vendors asking upper 200's for them. Looking again upper 300's seems more realistic.
Old Nov 8, 2010 | 03:07 PM
  #1683
Sacch's Avatar
what is '2 p's and a tripod'?
Old Nov 8, 2010 | 03:29 PM
  #1684
NFSP G35's Avatar
? = 2B || !2B
^what on earth are you talking about???
Old Nov 8, 2010 | 03:32 PM
  #1685
Sacch's Avatar
Lyrics from an eminem song lol. he said, "set up the camera, **** twice on her, look two p's and a tripod" lol
I was wondering if its an actual photography term lol, cause there is a photography website called two peas and a tripod.
Old Nov 8, 2010 | 03:34 PM
  #1686
The Stimulation's Avatar
I posted this in the "have a question about wheels" thread - no response...
I'm considering a used set for sale, need to decide soon... can anyone help?
Mike, if it helps any. I was at approx -2.4 degrees camber in the front with a 9.5 +3. When I threw on a 15mm spacer I had to dial in -4.7 camber and it poked out a couple mm more. 2.3 degrees got me maybe 17-18 mm further out (15mm plus whatever extra it got pushed out). For the rear I'm unsure.
Old Nov 8, 2010 | 03:40 PM
  #1687
CandlestickPark's Avatar
ill Sedan
Mike, I totally understand the question, I'm just not 100% sure on the ratio of mm to camber either. I thought it was 5mm ~ 1 degree of camber, but I'm not sure. I'll ask the guys in the stretched/aggressive thread, I'm sure they can give me an answer. Once we have that ratio we will be able to calculate everything. Need to know your tire sizes too, I assume 245/35, 275/35 (or 30 series).
Old Nov 8, 2010 | 04:16 PM
  #1688
Swivel's Avatar
Moderator
^^ Answered in the "question about wheels" thread. For our size tires, it seems to be about 5-6mm per degree.
Old Nov 8, 2010 | 10:36 PM
  #1689
OCG35's Avatar
thanks for the responses guys... I might keep looking for more ideal offsets...
Marcus, the tire width will be as wide as possible without bulge or stretch... probably 245/35 and 275/30
Old Nov 8, 2010 | 11:47 PM
  #1690
ill Sedan
Mike I talked to Grant tonight he said assume 1 degree of camber is 5-7mm.
Dave also confirmed this via math:
Originally Posted by Matzo Ball Soup
pretty much, use a trig formula with a right angle triangle. I created a formula for you to use...
In this pic, visualize your wheel well. The angle is front the center point of your wheel. The angle (theta) will be the degree change in your camber setting. Side CB (adjacent side) will be your wheel + tire height. Side AB will be your clearance (opposite side)
remember: tan(angle theta) = opposite side(AB)/adjacent side(CB)
therefore: to figure out opposite side length (AB) you must have the following algabraic formula:
tan(angle theta) x adjacent side (CB) = opposite side (AB)
tan(theta)xCB = AB
theta = tan(1*) = .0175
CB = Sidewall height (mm) + (Wheel diameter in mm/2) {note 1in = 25.4mm)
AB = clearance (mm)
theta(CB) = AB
Here is what I ran for my car today. Running a 255/35/19 rear
Sidewall height = 255(.35) = 89.25mm
Wheel Diameter = 19"(25.4) = 482.6mm/2 = 241.3mm (radius)
CB = 89.25+241.3 = 330.5mm
.0175(330.55) = 5.78mm overall change in clearance from the fender line w/ a 1* change in camber (+ or -)
Given that you don't want to run much neg camber, like you said, you may need to look for slightly higher offsets.
Old Nov 8, 2010 | 11:57 PM
  #1691
OCG35's Avatar
Thanks Marcus, much appreciated! I would need to study the formula much longer to grasp the principal (hated it in school, and still not warm & fuzzy about it ) - but the original suggesting of 6mm/1* apparently is right.
It's looking like finding the right offset (reasonably lightweight) wheel used isn't gonna happen on the G or Z forums... Flaring the fenders presented a predicament that I didn't think would be this challenging.
There is an awesome wheel that comes in perfect specs (size/offset/weight) but is 3600-4200 I was trying to avoid that but alas the spending remains inevitable for the ideas I have with this car.
I really need an NSX
BTW, what thread is the post you copied? *edit - nvrmnd, I clinked the arrow and it took me to thread
Old Nov 9, 2010 | 07:38 PM
  #1692
SN00P's Avatar
CLUB MODERATOR
anybody polishing their motors ??? i talked to sean about doing the matching power steering and overflow tanks and need at least 10 people interested in them !!!
ANYONE ???
Old Nov 9, 2010 | 08:28 PM
  #1693
OCG35's Avatar
^^^ possibly, depending on price... price would have to be real good 'cause I'm gonna hafta spend a grip getting 'em black chromed.
Old Nov 9, 2010 | 08:31 PM
  #1694
SN00P's Avatar
CLUB MODERATOR
the price will be $320 shipped !!! they normally cost $410 shipped
Old Nov 9, 2010 | 09:00 PM
  #1695
OCG35's Avatar
I'm local - I wonder how much picked up?... I'll hit up Sean later ~
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
