Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Nov 11, 2010 | 08:12 PM
  #1741
thescreensavers's Avatar
Mr.202?
What info shows up when you plug into the OBDII port?
Do you get oil temp? Tranny temp? Pressure?
Just wondering if I should buy this bluetooth OBDII scanner so I can use my phone with it, or just buy a cheapy one just to read and clear codes.
Old Nov 11, 2010 | 10:38 PM
  #1742
NFSP G35's Avatar
? = 2B || !2B
^LOTS of stuff.
I can give you a full list of everything mine reads tomorrow, just don't let me forget.
Old Nov 11, 2010 | 11:25 PM
  #1743
Mr.202?
Originally Posted by NFSP G35
^LOTS of stuff.
ok DONT FORGET! lol
The app is called Torque. But I guess its limited by what it can show on my phone :O
it seems I can add w/e I just need to find the PID number
Old Nov 12, 2010 | 04:31 PM
  #1744
hL.'s Avatar
hL.
I just did my ATF change yesterday (drain & fill).
Only ~3 quarts came out. Is this normal? I've done some research and most people can drain about 5 quarts.
Old Nov 12, 2010 | 05:28 PM
  #1745
OKStateG35's Avatar
Mine was about 3.75. From what I've read, it varies between 3 and 5. Probably depends on how your car is lifted and how long you let it drain. I wouldn't worry about it as long as you put back the same amount removed.
Old Nov 12, 2010 | 05:34 PM
  #1746
hL.'s Avatar
hL.
Thanks for the feedback! Only the front side of my car was jacked up. Which leads me to conclude that, to get ~5 quarts out, the car must be level? Can anyone confirm this?
Old Nov 13, 2010 | 01:20 PM
  #1747
OKStateG35's Avatar
My car was level when I did it and I didn't get 5 quarts so I'm not sure how they are getting that much out.
Old Nov 13, 2010 | 09:47 PM
  #1748
DivZero's Avatar
How do I replace the bulb in the side marker type light? Just pop out a couple fender clips and voila?
Old Nov 13, 2010 | 09:53 PM
  #1749
CandlestickPark's Avatar
ill Sedan
^IIRC....Pull the side marker off (you can remove with our hands, no tool needed). On the backside of the side marker the light housing needs to be turned like a 1/4 turn which will allow you to access the bulb. Pull the old one out, insert the new one in its place. Do all of this in reverse to reinstall.
Old Nov 13, 2010 | 10:37 PM
  #1750
NFSP G35's Avatar
? = 2B || !2B
^Correct.
Side marker comes out by pulling outwards on the "back" (the part closest to the tire, in the wheel well) and slightly back after it pops off.
Plug turns about 1/4 turn and then straight out, bulb pulls straight out of plug.
Old Nov 13, 2010 | 10:48 PM
  #1751
OCG35's Avatar
pull it till you think its gonna break (literally) right when you think it's gonna bust right in half, whalla it's off undamaged.
Old Nov 13, 2010 | 10:59 PM
  #1752
NFSP G35's Avatar
? = 2B || !2B
^That, or in extremely rare cases, it will break into 10,000 pieces, cut your hand, your car will explode into flames and likely kill your dog.......
.........but that's only happened like once
Old Nov 13, 2010 | 11:09 PM
  #1753
naughty240's Avatar
Its easy to run a thin pocket type flat head behind it too. Pops off a lot easier than pulling.
Old Nov 14, 2010 | 12:40 AM
  #1754
DivZero's Avatar
Wow thanks guys. Very helpful. I hope it doesn't do what NFSP says it might. Lol
Old Nov 14, 2010 | 12:42 AM
  #1755
Hammerhead i-Eagle Thrust's Avatar
it wont...just use your hands, they pop right off
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
