Random Little Question Thread
#2795
Service Engine Soon light came on.
went to autozone.
this was the readout:
TP sensor circuit range/performance problem -
TP 1 & 2 signals do not agree
Probable cause
1. Open or short circuit condition
2. Poor electrical connection
3. Failed TP sensor
I disconnected the battery and the light is gone for now.
what could it be?
is it expensive to fix?
went to autozone.
Probable cause
3. Failed TP sensor
what could it be?
#2796
ill Sedan
#2797
ill Sedan
#2799
ill Sedan
#2803
Nothing wrong with the eBay spoilers. I have one, sn00p has one, thescreensavers has one, just to name a few.
Just make sure you order it custom cut to1170mm
As for staggered wheels on an x, make sure the tire diameter is as close as possible to the same.
Here's how to calculate it:
using a 245/40R19 as an example-
245x0.40x2
devide by 25.4
add 19 (wheel size)
do that for both tire sizes you plan to run.
The results should be as close as possible (can't remember how close, but I'd aim for .2 or less)
245x0.40x2
devide by 25.4
add 19 (wheel size)
#2805
ill Sedan
