Random Little Question Thread
#2851
#2852
Let me get those now.
Here's the difference between a D2S (left) and D2R (right)
I wonder if they're interchangeable, just different ratios.
Were the part numbers different on the Sedans, Coupes, or both?
#2856
#2857
#2860
#2861
I think there is a red light below that, that flashes when you need to shift from watching some of the videos i have seen. However I'm still unsure what the actual light is for.
#2863
lol what?
Some cars have different ratio steering boxes from one year to another or between models, yet they're interchangeable.
Subaru is a good example. The STi has 'tighter' steering because the steering box is geared differently and the car has less turns lock-to-lock. Yet, you can still swap it into an Impreza.
I don't know if that's the case with the G, but it would be easy enough to test.
If a 05 and 06 have the same number of turns, there's probably some other difference. But if a 05 and 06 have different number of turns, it's a fair bet the only difference is just the ratio.
#2864
#2865
