Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #3361
Old 03-26-2011, 11:12 PM
IPGSEDAN's Avatar
Are doors interchangeable between 03-04 and 05-06 sedans?
  #3362
Old 03-26-2011, 11:57 PM
NFSP G35's Avatar
? = 2B || !2B
^Yes and no.
The door itself is the same, but he interior door panels is different, as well as the door's internal wiring harness (although that can be swapped from your existing door)
  #3363
Old 03-27-2011, 11:19 AM
Matzo Ball's Avatar
Will Stoptech rotors for non brembo G35 coupe fit the X?
  #3364
Old 03-27-2011, 11:25 AM
Swivel's Avatar
Moderator
^ I would check with Charles at B2Autodesigns. Don't see why not if they are the same diameter....?
  #3365
Old 03-27-2011, 11:31 AM
Matzo Ball's Avatar
sent him a PM. Rotors are for an '05 Coupe and i have an '04X.
  #3366
Old 03-27-2011, 04:41 PM
IPGSEDAN's Avatar
Originally Posted by NFSP G35
^Yes and no.
Thank you!
is there any difference in shape not fitment wise but style wise (if that makes any sence) from 03-04 doors to 05-06 doors?
  #3367
Old 03-27-2011, 07:50 PM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
No they wont. The 03-04 sedans and 05 Xs had different calipers and rotors. The 03-07 non brembo coupes, the 05-06 sedans, and the 06 Xs all have the same brakes.
  #3368
Old 03-27-2011, 08:33 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by The next best
Thank you!
No. Visibly, the outer part of the door is identical.
  #3369
Old 03-27-2011, 11:59 PM
D.Reaper's Avatar
what wattage are you guys using for the yellow fog light bulbs?
  #3370
Old 03-28-2011, 12:16 AM
thescreensavers's Avatar
Mr.202?
^ I used 35watt HID's
  #3371
Old 03-28-2011, 01:15 AM
D.Reaper's Avatar
i'd rather just use yellow bulbs, i dont use them that often...what wattage is good to go with on those? i had thought at most 50
  #3372
Old 03-28-2011, 09:28 AM
Matzo Ball's Avatar
Thanks.
Is it the OEM rotors or brake pads that cause the rediculous amount of brake dust? Would Stoptech/Powerslot/Centric rotors and new pads eliminate this??
  #3373
Old 03-28-2011, 12:10 PM
Blue Dream's Avatar
OEM rotors on 03-04 cars are the culprit. They stop great but dust a ton. You don't necessarily need to change out the rotors, but definitely go with the aftermarket pads. Nissan redesigned the pads for the 05 and up.
  #3374
Old 03-28-2011, 12:58 PM
Matzo Ball's Avatar
which pads (most quiet)?
  #3375
Old 03-28-2011, 02:40 PM
NFSP G35's Avatar
? = 2B || !2B
I use 55, but most use 35
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
