Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #2611
Old 01-18-2011, 07:55 PM
ilv2xlr8's Avatar
If installing 19" M45 sport wheels, should I be getting V1 or V2 spacers? I'm not 100% on what the bottom of their page says in terms of solid surface.
http://www.ichibausa.com/15albowhsp6.html
EDIT: Also, which lugs do you need for the M45? Shank or?
  #2612
Old 01-18-2011, 08:28 PM
Swivel's Avatar
Moderator
Originally Posted by cremaster
has anyone use Slick 50 fuel treatment before? i just picked up a bottle but haven't poured it into the gas tank yet. see any difference in smoothness in the engine?
i've had my throttle body and fuel injection cleaned back about 30k miles ago.
No experience with Slick 50 but personally I wouldn't if your engine is running fine. Heard horror stories about Restore; different product I know, but it seems VQs don't like additives.
  #2613
Old 01-18-2011, 09:00 PM
NFSP G35's Avatar
? = 2B || !2B
So, I just realized the projectors I ordered are D1S....
I'm going to be using a DDM HID kit, but their D1S kits are a lot more expensive.
Anyone know what other bulb style would be easiest to adapt to fit?
  #2614
Old 01-18-2011, 09:34 PM
NFSP G35's Avatar
? = 2B || !2B
Nevermind. Found it. D2S.
  #2615
Old 01-19-2011, 06:06 AM
VincenzG35's Avatar
Anyone ever replace there H1 with an Led if so how's the output I want it to have a more xenon look like the hids
  #2616
Old 01-19-2011, 09:23 AM
CG4DR's Avatar
Why not buy a h1 hid kit?
  #2617
Old 01-19-2011, 09:25 AM
NFSP G35's Avatar
? = 2B || !2B
^+1
  #2618
Old 01-19-2011, 10:13 AM
GOAT35's Avatar
RIM QUESTION!!!!
Lost some rivets for my rim... well the shop did while fixing the curb rash!
Im only missing 2 out of 10 but these aren't plastic these actually left holes in the rims!
I took them off and back on my 18s for now my question is are they still safe to drive on the shop guy said yes since its only 2 missing but he was shady!
They didn't even charge me after I noticed they were missing.
Also can I replace em??? Anyone know how/where? Thanks
  #2619
Old 01-19-2011, 11:49 AM
hashrock's Avatar
DD with OEM Nav but no JDM/Metra kit or faceplate?
2003 sedan here w/OEM Nav. So I want to replace my HU with a DD. The question is do I need to purchase an separate AC controller or is it possible to just Dremel the existing face and slide in a new DD? Looks not withstanding, is it possible and still have a fully functioning AC? I can get whatever I need machined by a friend to make it fit.
I would spring for the aftermarket kits, but I've got the burlwood interior which they don't make a kit for. I also don't want to lose my OEM Nav.
  #2620
Old 01-19-2011, 12:00 PM
NFSP G35's Avatar
? = 2B || !2B
^Sorry, not possible. The radio and ac controls share a common circuit board
  #2621
Old 01-19-2011, 12:08 PM
hashrock's Avatar
Thanks - I suppose I'll have to sell my entire console on ebay. I see people listing it for $700 but I doubt anyone is paying that much.
  #2622
Old 01-19-2011, 12:33 PM
cremaster's Avatar
dammit! what to do, what to do... yeah, it's running fine but thought i'd give it a little cleaning, anyway. hmmm..
  #2623
Old 01-19-2011, 12:36 PM
Wannabe6MT's Avatar
-MN G Crew-
Soooooo 2 nights ago, it was about -25degrees with wind. Yesterday morning I woke up and at about 10am, went tos tart my car to drive to class. It was probably -10 then.
Started the car, turned over very slowly and the whole car started shaking Lol kinda freaked me out. Then it idled really rough and low, then just died. I was like "wtf" started it back up and it seemed to run fine albeit idling high and being very frozen.
Gave it 3 minutes to warm up, then i drove very slowly and kept the revs under 2k until it fully warmed up. Everything felt frozen, it was brutal. Tranny shifted hard, steering was hard, everything was just frozen.
Everything else I understand, but my car idling weird then dieing, that freaked me out a bit. Anyone else experience that?
  #2624
Old 01-19-2011, 01:25 PM
VincenzG35's Avatar
I don't have experience with wiring I'd have no clue how
  #2625
Old 01-19-2011, 01:36 PM
xxxxxxxxxx's Avatar
Originally Posted by G35Papa
SPC will allow you to dial in more positive camber (via the shim kit it comes with) over Ichiba...but, SPC is not recommended for aggressively lowered (2+ inches) cars as the A-arms have been known to knock.
So it really depends on how low you go and whether you want to try and get as close to OEM spec as possible.
Another option are the SPL arms which IIRC, will give you more positive camber correction than ichiba..but, stay away from the version 1 of those arms as they too were known to have a knocking issue on aggressively lowered cars.
so i should go with ichiba for the front? cus im preety low ,from my front fender to the grown is like 23.5 inches
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
