Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #2596
Old 01-16-2011, 05:09 PM
NFSP G35's Avatar
? = 2B || !2B
^But the 03/04s suck.
Sure they bite good, but they dust SOOOOOO bad. It's unbelievable
  #2597
Old 01-17-2011, 10:48 AM
CG4DR's Avatar
should i leave my strut bar chrome or pc it glossy black?
  #2598
Old 01-17-2011, 10:58 AM
NFSP G35's Avatar
? = 2B || !2B
^Either would work.
Black keeps with your theme, but chrome gives it contrast against your plenum.
  #2599
Old 01-17-2011, 01:36 PM
VincenzG35's Avatar
Would a 2007 shift **** fit a 2003? (auto)
  #2600
Old 01-17-2011, 02:05 PM
geoffkiefs's Avatar
Factory sub only put's out minimal bass even when turned up as high as it gose, All the speakers work but there is minimal bass? is it the AMP? I have a aftermarket AMP at my house that I do not use anymore can I switch the factory AMP with the aftermarket one to get some bass back without switching all the speakers and getting a head unit and aftermarket subwoofer?
  #2601
Old 01-17-2011, 04:15 PM
Epidel's Avatar
Is there a big difference between ichiba version 1 and version 2 spacers?
  #2602
Old 01-17-2011, 04:21 PM
The Stimulation's Avatar
Depends what you consider big. But the difference is that the v2's have built in extended studs. v1's have extended studs where you'd have to take out the current ones and replace with the longer ones that come with the v1's.
  #2603
Old 01-17-2011, 08:50 PM
NFSP G35's Avatar
? = 2B || !2B
Just wanted to double check... OEM Halogen lowbeams (non-HID) are an H1 bulb, right? That's what Sylvania's site said.
  #2604
Old 01-17-2011, 09:21 PM
G35Papa's Avatar
^yes
  #2605
Old 01-17-2011, 11:40 PM
Epidel's Avatar
OK thanks i is educated meow !
  #2606
Old 01-17-2011, 11:48 PM
No prob, haha
  #2607
Old 01-18-2011, 02:01 AM
xxxxxxxxxx's Avatar
ichiba front camber kit or spc?
  #2608
Old 01-18-2011, 04:03 AM
VincenzG35's Avatar
anyone know if 07 shift ***** fit the 03-04 i cant find a thread (ps anyone have a blk 2007 + shift **** A/T for sale let me know )
  #2609
Old 01-18-2011, 02:34 PM
G35Papa's Avatar
SPC will allow you to dial in more positive camber (via the shim kit it comes with) over Ichiba...but, SPC is not recommended for aggressively lowered (2+ inches) cars as the A-arms have been known to knock.
So it really depends on how low you go and whether you want to try and get as close to OEM spec as possible.
Another option are the SPL arms which IIRC, will give you more positive camber correction than ichiba..but, stay away from the version 1 of those arms as they too were known to have a knocking issue on aggressively lowered cars.
  #2610
Old 01-18-2011, 07:14 PM
cremaster's Avatar
has anyone use Slick 50 fuel treatment before? i just picked up a bottle but haven't poured it into the gas tank yet. see any difference in smoothness in the engine?
i've had my throttle body and fuel injection cleaned back about 30k miles ago.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
