Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Apr 6, 2011 | 05:00 PM
  #3511
Blue Dream's Avatar
I drove ttrank's car solo
Can a small exhaust leak lead to a noticeable power loss?
Replacing my drivers side rear axle I noticed water dripping between my midpipe and muffler. Found a gap between the flanges so I bent them back straight and put a new gasket between them. The car feels noticeably peppier than before, especially with initial acceleration. I know it's not my imagination, but the only thing that changed was sealing off that leak.
Old Apr 7, 2011 | 01:12 AM
  #3512
itgogitrev's Avatar
FITMENT QUESTION!!!
04 Sedan, full revised Z suspension, slightly rolled front fenders, unrolled rears.
Found a set of wheels I'm in love with, but they only come in 18x9.5 et20.
What am I looking at in terms of camber and tire size? Fenders and rear quarters will eventually be rolled flat.
Old Apr 7, 2011 | 06:40 AM
  #3513
VincenzG35's Avatar
Originally Posted by Dnorwood
could also be a ball joint, had that happen in my 99 avenger, and the sealed ball joint boots had gone dry .
Yea our ball joints are made without grease fittings most of the time they make noise there perfectly fine they just go dry im working on adding a grease fitting or some type of fix for it to test it spray WD40 on your joint above your tires if its now quiet you've found your problem
Old Apr 7, 2011 | 06:41 AM
  #3514
VincenzG35's Avatar
Who's in charge of g35 driver I have a question for an admin
Old Apr 7, 2011 | 11:10 AM
  #3515
NFSP G35's Avatar
? = 2B || !2B
^Kinda depends on what you mean by "in charge of"
G35Driver was sold to InternetBrands, so technically, they're in charge of the site itself.
Robb M. is the point of contact for IB
But if it's related to something more along the lines of changing a username, or if you account status is wrong, etc... contact one of the 'Red Username' admins.
https://g35driver.com/forums/showgroups.php
Old Apr 7, 2011 | 02:11 PM
  #3516
D.Reaper's Avatar
broke a wheels stud, in the middle of trying to change it out...i took off caliper, but now cant seem to get rotor off...this is for the rear...i dont see anything holding the rotor in place, but it will not come off...some please help
Old Apr 7, 2011 | 02:18 PM
  #3517
SN00P's Avatar
CLUB MODERATOR
Rubber mallet or hammer and just tap all atound the back of it and it should start to move. Sometimes they get rusted on there and spray some stuff in there ane you should be good
Old Apr 7, 2011 | 02:31 PM
  #3518
G35Papa's Avatar
Make sure the ebrake is off. Take a mallet and hit the rotor hat around the wheel studs. YOu can also spray some penetrant around the hub which is where it is getting stuck.
Old Apr 7, 2011 | 02:36 PM
  #3519
NFSP G35's Avatar
? = 2B || !2B
One of my rotors was stuck on the hub crazy tight.
It was on the back. Passenger side IIRC.
I had to beat the crap out of it with a 5lb sledge
Old Apr 7, 2011 | 02:49 PM
  #3520
TurTLe*'s Avatar
^ you have a 5lb sledge in your tool box? your in FL, rotors aren't as bad there.
in the midwest when all the salt. you get rotors rusted to hubs completely. never needed 5lb sledge. maybe you weren't hitting it right (thats what she said)
small love taps are better then beating the crap out of one.
Old Apr 7, 2011 | 02:53 PM
  #3521
NFSP G35's Avatar
? = 2B || !2B
^I started with small love taps with a ball-peen hammer, then graduated to more convincing blows with a regular claw hammer and still got nowhere, so I beat the holy hell out of it with a 5lb sledge, and whaddaya know it came off
The fronts just fell off, and also the other side in the back wasn't as bad.
Don't ask me
oh and yes, I had released the parking brake. I even spun the little adjustment thing to retract the shoes completely.
Old Apr 7, 2011 | 03:27 PM
  #3522
WG35's Avatar
I found this thread at random.
This guy is my step brother's double.
Here is a picture of Mike, my brother, with me at my wedding.
uncanny huh!
http://www.flickr.com/photos/61382694@N03/5598798242/
Old Apr 7, 2011 | 03:35 PM
  #3523
VincenzG35's Avatar
Spray some WD40 and tap with a hammer wrapped in a cloth/rag /old t shirt
Old Apr 7, 2011 | 10:23 PM
  #3524
CG4DR's Avatar
if you already broke a stud, knock it out and use that spot to hammer the hell out of it till the rotor pops off.
Old Apr 9, 2011 | 01:12 AM
  #3525
NFSP G35's Avatar
? = 2B || !2B
Can someone explain why I can't get these: http://cgi.ebay.com/ebaymotors/ws/eB...m=390275541313
or these: http://cgi.ebay.com/ebaymotors/ws/eB...m=190511349505
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
