Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Apr 3, 2011 | 12:14 PM
  #3481
nazc0's Avatar
2006 Vortech supercharged Sedan
guys i tried searching but no luck, are the front fenders the same for 03-04 and 05-06?
Old Apr 3, 2011 | 12:29 PM
  #3482
NFSP G35's Avatar
? = 2B || !2B
^From what I read they are
Last edited by NFSP G35; Apr 3, 2011 at 12:58 PM. Reason: Cellphone keyboard randomness FTL!
Old Apr 3, 2011 | 12:49 PM
  #3483
NjMatteSedan's Avatar
^ +1
Old Apr 3, 2011 | 01:02 PM
  #3484
NFSP G35's Avatar
? = 2B || !2B
Anyone ever shipped a 03/04 muffler? I need to know how much they weigh and I don't really feel like taking it off just for that.
Alternately, if someone has one laying around that they could weigh?
Old Apr 3, 2011 | 01:38 PM
  #3485
nazc0's Avatar
ill weigh mine today since its off the car, thanks for the info on the fenders ill be able to confirm this or disprove it today
Old Apr 3, 2011 | 03:50 PM
  #3486
TurTLe*'s Avatar
TPMS they work on 2nd gens as well ? vice versa? ideas?
i've seen pictures they are exactly the same LOOKING but i dont know if they are on the same freq. I dont see why nissan would switch up the freq. maybe to make more money or better readings.
Old Apr 3, 2011 | 04:02 PM
  #3487
The Stimulation's Avatar
Really? Front fenders are the same? I figured they'd be slightly different because the headlights are shaped differently.
Old Apr 3, 2011 | 11:02 PM
  #3488
xxxxxxxxxx's Avatar
is the muffler from a 04 g35x the same as a 04 g35 rwd ?
Old Apr 4, 2011 | 12:07 AM
  #3489
the headlights are shapped differently on the bottom, where it meets the bumper the top is the same
Old Apr 4, 2011 | 12:09 AM
  #3490
ridinG's Avatar
I just lubed my brakes with some high temp caliper grease and so far it seems like the squeaking I was hearing when not braking is gone. Who knows how long it'll last though.
I have a new problem now. My steering wheel now has a shimmy to it once I hit around 65mph...which was not there the drive before I started the brake lubrication job.
All I did was take off the (front) wheels, take out the bottom caliper bolt, pivot the caliper, remove the pads, and lube all metal to metal contact points...like the piston-inboard pad, pad & shim, caliper-outboard pad, and the pad seats.
I did this to the front wheels only. Tried to do the rear wheels but my ratchet&socket wouldn't fit on the caliper bolt, grabbed a 14mm wrench and proceeded to strip the bolt , so I left that wheel (rear left) alone. Moved over to the rear right, but as I was jacking the car up, those tabs started to bend so I just let the car done & said screw it.
What could I have done that caused this?
Old Apr 4, 2011 | 10:57 AM
  #3491
Abax84's Avatar
Mine weighs 18.8lbs with out tips, and its cut right behind the muffler, so I dont know if that helps..
Old Apr 4, 2011 | 11:14 AM
  #3492
NFSP G35's Avatar
? = 2B || !2B
^Yep. That helps
Old Apr 4, 2011 | 01:00 PM
  #3493
DR.D69's Avatar
Mine weighs 19.98 lbs and thats with about 6-7in of pipe on the back and its from an 05 RWD sedan. Hope that helps!
Edit: Wait nevermind misread the post...
Old Apr 4, 2011 | 06:55 PM
  #3494
AwdGx's Avatar
does anyone know any solutions on fixing the cup holder on 05-06 sedans? i cant get it to stay down or stay up.
Old Apr 4, 2011 | 08:07 PM
  #3495
GreenPenguin's Avatar
Time for new struts. I've got 76k miles on the sport tuned suspension with unrevised Z springs. When I hit a pothole or imperfection in the road I really feel it. I want that "Lexus/Toyota" feel! Would you guys recommend D-specs, OEM, 350z or something else?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
