Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Apr 20, 2011 | 12:38 AM
  #3631
thescreensavers's Avatar
Mr.202?
Originally Posted by SN00P
well FML i think my main engine bearing is going out cause in hight RPM's 1st gear im getting a bad cluttering noise that get LOUD !!!! ughhh always something but extended warranty FTW
anyone have any clue what it could be ?
Don't forget to remove engine mods before the dealer, if it's oil related issue, did you go too long on an oil change? Maybe the previous owner
Old Apr 20, 2011 | 12:54 AM
  #3632
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by D.Reaper
to tap into for high beam, or from projector?
On the OEM harness: Black=ground, Red=High-beam. Hook those to the solenoid and you're golden.
(Double check the polarity, I'm not sure if it makes a difference, but you should check anyway)
Old Apr 20, 2011 | 03:11 AM
  #3633
ilv2xlr8's Avatar
What is a fair price for curbed (no cracks, more than average curbed-ness) 18" G35 coupe wheels in gloss black?
Old Apr 20, 2011 | 10:42 AM
  #3634
JaysG35x's Avatar
Just ordered Berk high flow cats do i need any gaskets or anything before install or do they come everything I need? thanks
Old Apr 20, 2011 | 02:11 PM
  #3635
G35Papa's Avatar
^You'll need to buy new gaskets for both ends
Those Maybach chrome rings must have been like what 2 or 3K?
2.5k
Old Apr 20, 2011 | 02:16 PM
  #3636
NFSP G35's Avatar
? = 2B || !2B
^Read: $2.50
Old Apr 20, 2011 | 02:19 PM
  #3637
Wannabe6MT's Avatar
-MN G Crew-
BTW, just letting you guys know that I have speakers for sale that fit the first gen sedan, i have a double din headunit for sale that fits it, I have coupe rear springs (for those that want to do the Z/G spring combo) and I have a polished plenum from SXEXCX.
Check my threads yO!
Old Apr 20, 2011 | 02:23 PM
  #3638
OCG35's Avatar
I've had my cats on/off several times - always reused gaskets... replacement is not necessary unless they are bent or otherwise damaged.
Old Apr 20, 2011 | 11:55 PM
  #3639
NjMatteSedan's Avatar
are yellow hids fogs blinding like 8000K hid fogs? i have 8000K top and bottom but the top ones are not blinding, i guess the bottom are cause they share the high beam location
Old Apr 21, 2011 | 12:03 AM
  #3640
NFSP G35's Avatar
? = 2B || !2B
^Yes, 3000k are still very bright and will be very blinding if not aimed properly.
I believe the solution is a bulb that has a shield on it to cut-off the upper part of the beam and make the fog light disperse light more like the low-beam.
Only thing is, you might not have high-beams anymore, depending on the type of bulb you use.
I'm not completely sure how all that works or what bulb to use though, as I have switched to projectors
Old Apr 22, 2011 | 03:07 AM
  #3641
nas's Avatar
nas
guys am having badddd fuel odor in the car whenever i hit the pedal like full throttle or even halfway it smells really bad + relatively low mileage and the exhaust tips r black indicating rich a/f mixture, my g35 got jwt intake gutted cats power pulleys spacer and all other stock any ideas??
Old Apr 22, 2011 | 08:04 AM
  #3642
NFSP G35's Avatar
? = 2B || !2B
^Try putting your stock intake tube back on and reset the ECU.
Old Apr 22, 2011 | 09:57 AM
  #3643
VincenzG35's Avatar
About to order a part before i do can someone confirm what part this bushing is its right above my driverside tire
Old Apr 22, 2011 | 10:11 AM
  #3644
NFSP G35's Avatar
? = 2B || !2B
^How much you paying to get that done? I can get you the entire arm with bushing installed...
Old Apr 22, 2011 | 12:04 PM
  #3645
VincenzG35's Avatar
i dont know yet i was trying to name this part so i can look into replacing it i believe my sho[ charges 153$ to press a bushing in and out but i need the name i believe its a control arm correct?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
