Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Apr 18, 2011 | 01:58 AM
  #3601
NFSP G35's Avatar
? = 2B || !2B
^How the heck!? I have a 2.5" projector and looked at putting it in the turn signal, and it was not even CLOSE. I don't think I could have trimmed the housing enough to get it close to fitting.
I wonder if the difference in the 03/04 blinker housing and the 05/06 is actually that much different?
Old Apr 18, 2011 | 02:03 AM
  #3602
CandlestickPark's Avatar
ill Sedan
Might be a bit different. I'll ask RRYDE, he knows the exact sizes of the turn signals since he's worked on both.
Old Apr 18, 2011 | 07:38 AM
  #3603
NjMatteSedan's Avatar
Is there anyway to replace the gauge cluster plastic cover without having to buy a whole cluster? Mine has a crack on it
Old Apr 18, 2011 | 01:39 PM
  #3604
D.Reaper's Avatar
candlestick: how is that projector held in there? that's exactly how i want it to look
Old Apr 18, 2011 | 02:31 PM
  #3605
G35Papa's Avatar
Originally Posted by NFSP G35
^From what I've heard, some of them grind them down
I know Papa Chris tried that route with little success, but he may have found another option... we should hear from him soon enough.
Did somebody say my name?
I was able to grind one down enough to fit....after about an hour of grinding, I nicked it a little and just gave up because I wanted no scratches
I used a grinding stone on my dremel.
I have 2.5" TSX projector lenses in my turn signals. The opening of my turn signal housing was dremeled out a bit to make it larger. We installed the lenses from the inside of the housing vs placing it on top and secured it with some pretty strong glue.
I think they are a little bigger in the 05/06s. I remember Randy telling me all he had to do was grind the small lip around the lenses. I had to dremel out more than that to make it fit.
So yeah, I gave up and did this.
Used some chrome rings out of a Maybach finishing kit (inside joke to Marcus ) and hacked up a set of projector fog lights
I still have to do the other side and get them installed. May add some demon eyes behind them as well
Old Apr 18, 2011 | 02:50 PM
  #3606
617DG35x's Avatar
interesting...I have an 06 sedan and been wanting to do this for some time now. I may go this route. 2 questions though, Did you have to dremel the projector lens at all or just the housing? And what kind of glue did you use? I don't suppose super glue cause that stuff leaves residue behind, no? I appreciate any help.
Old Apr 18, 2011 | 02:52 PM
  #3607
NFSP G35's Avatar
? = 2B || !2B
^I used a hot glue gun when I did mine. That part of the light doesn't get hot enough to melt it, and it's easy to work with.
Old Apr 18, 2011 | 04:32 PM
  #3608
G35Papa's Avatar
First you dremel the orange lense out of the turn signal bezel. From there you will need to grind down the projector lense until you get it to the right size to sit inside the turn signal bezel.
Old Apr 18, 2011 | 07:57 PM
  #3609
NFSP G35's Avatar
? = 2B || !2B
I have to recant my last statement.
Upon taking my headlights back out today, the hot-glue was melted, and a pain in the butt to clean up
Old Apr 18, 2011 | 09:57 PM
  #3610
GreenPenguin's Avatar
To avoid the "springmount mod", what do you guys think of running Z Htechs in the front and unRevised Z springs in the back on Tokico Dsp9's? It's probably not a good idea to mix linear and progressive springs but it will give the appearance of a more even drop than just the htechs alone. What you think?
Old Apr 18, 2011 | 10:45 PM
  #3611
STCLAIRWEST's Avatar
I ran that for a bit before I got my coilovers
Hope this helps
Old Apr 19, 2011 | 12:57 AM
  #3612
ill Sedan
I measured RRYDE's turn signal template today for 05/06 Sedans and its 2.5 inches, so it must be larger than 03/04s.
We didn't grind down the projector itself but dremelled the housing a tad to make it fit in there properly.
Old Apr 19, 2011 | 03:19 AM
  #3613
VincenzG35's Avatar
can someone photoshop Koing Unknows on my car please
Old Apr 19, 2011 | 03:48 AM
  #3614
xxxxxxxxxx's Avatar
quick question: would a 19x10 +10 offset rim fit in front and 19x10 +5 rear?
Old Apr 19, 2011 | 05:47 AM
  #3615
Hope this helps
It does! Thank you sir! How long before you wanted "more low" on that set up?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
