Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Apr 14, 2011 | 05:01 PM
  #3586
The X Factor's Avatar
Random question...what's with all the armor all ads? Are they paying to advertise or just randomly spamming?
Old Apr 14, 2011 | 05:33 PM
  #3587
VincenzG35's Avatar
No clue but I'm a meguires guy anyway
Old Apr 14, 2011 | 09:27 PM
  #3588
NFSP G35's Avatar
? = 2B || !2B
More important random question... why don't you have AdBlock+ ?????
Old Apr 15, 2011 | 07:25 PM
  #3589
WILLIE BEANS's Avatar
so i replaced both my rear endlinks .. and installed my hotchkis sways finally lol
went to get the whiteline lower control arm bushings but they couldnt install them right away or do my alignment and i couldnt wait or go back that day.. so i bought the whiteline bushings ..n came home .. thinking il just get em installed locally ..
decided id go to a local good year for their free alignment check. figured why not ..
they said i needed a few adjustments to be back in spec and my stock L.C.A. bushings were in good shape . so i had them do the alignment and the car feels great . guess il install the L.C.A. bushings later on..... whene i upgrade more of my suspenion ..
on a side note im getting that mysterious sound from the suspension .. probably the sways ...
Old Apr 15, 2011 | 07:39 PM
  #3590
CandlestickPark's Avatar
ill Sedan
Originally Posted by D.Reaper
having an issue with rubbing, but fenders have been rolled and pinched almost paper thin, rears also rolled and pinched 19x8.5 +45 with 25mm spacer 245/35/19 and 19x9.5 +40 with 15mm spacer 245/35/19...i think what is rubbing is either the front screw or back screw (middle screw and clip removed) or both...can i just take out front screw and clip? dont want my fender liner to hang and eventually get ripped off...just need to get this damn rubbing to stop
You can take the 2 screws and clip out your fender liner shouldn't hang down. Mine stayed in place but part of it is missing now from rubbing my tire.
Old Apr 17, 2011 | 07:00 PM
  #3591
CG4DR's Avatar
where can i find a part number for the JDM window visor deflector things?
Old Apr 17, 2011 | 09:58 PM
  #3592
hL.'s Avatar
hL.
Is it just MY sedan or does our trunks SLAM every time it closes? We do have heavy trunks.
But does anyone else have this problem? Are are my dampers busted?
Old Apr 17, 2011 | 10:00 PM
  #3593
TORETTO's Avatar
Dampers are probably effed.
Or at least with my coupe. The trunk didn't slam. I could actually keep it hovering open.
Old Apr 17, 2011 | 10:30 PM
  #3594
D.Reaper's Avatar
how big would a projector lens have to be to go in place of the amber plastic in our 05-06 headlights? i would like to change these when i do my retro
Old Apr 17, 2011 | 11:48 PM
  #3595
NFSP G35's Avatar
? = 2B || !2B
^2 1/4 inch, but they're really hard to find in that size. Most projectors that are close to that are 2 1/2, and that's just too big.
Old Apr 18, 2011 | 12:03 AM
  #3596
D.Reaper's Avatar
i found this: http://www.dealextreme.com/p/50mm-18...s-optics-12834 which they have 50mm available and 66mm...i know they ususally have a little lip that can be shaved down if needed (around as a border)...i would like to put it in from the inside of the housing and have it sit flush with pressure
Old Apr 18, 2011 | 01:38 AM
  #3597
NFSP G35's Avatar
? = 2B || !2B
^Trouble is, it's closest to 60 or maybe 58mm.
I'm not sure you could trim enough off the 66mm to get it to fit.
I would be interested to see what you come up with though.
Old Apr 18, 2011 | 01:42 AM
  #3598
thescreensavers's Avatar
Mr.202?
^ how do the other guys do the projector lenses then?
Old Apr 18, 2011 | 01:49 AM
  #3599
NFSP G35's Avatar
? = 2B || !2B
^From what I've heard, some of them grind them down
I know Papa Chris tried that route with little success, but he may have found another option... we should hear from him soon enough.
Old Apr 18, 2011 | 01:56 AM
  #3600
ill Sedan
I have 2.5" TSX projector lenses in my turn signals. The opening of my turn signal housing was dremeled out a bit to make it larger. We installed the lenses from the inside of the housing vs placing it on top and secured it with some pretty strong glue.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
