Random Little Question Thread
#3556
#3558
Im running an 8.5 +30 on all four and its fine up front.. bumps or rubs every once in a while... not sure about the rear, you'll need some fender work and camber if you're dropped - or plan to be.
#3561
#3562
sorry I got all sorts of confused for a second... i would do 45 in the front and 40 in the rear..
#3565
Im getting a squeak at slow (idle) to medium speeds that sounds to be only coming from the right rear, I cant say for sure but its only happening when I turn the car right. No squeak on left turns, or straight slow downs. My pads have about half life left in them. The brakes have been off the car lately for a spacer install, after that is when I started to notice the noise. Any suggestions as to what it is?
#3566
About to order some Tokico Dsp7's for my 2005 6mt sedan premium package. Question is, will I need to order the adjustable extensions for the rears or no? I think I read somewhere that those with the reclining rear seats like mine can access the rear tophat from behind the seat below some padding. I saw some coupe guys route their extensions up through the child safety seat anchors(pretty cool). I would like to do that too but only if it's necessary.
#3567
#3568
Received 1,486 Likes
on
#3569
^ Its intermittent but just barely.. I hear it during a tap or full pedal depression, sometimes even without the brakes applied. Speed and brake pressure don't seem to affect the volume of the squeak, so you're prob right about the lube. Should I try switching my rear pads? left pad to right vice versa...
#3570
Sweet! Thanks Bluedream! Do you have a pair or are you on coilovers? I'm gonna run my DSP-7's with my unrevised Z springs.
