Random Little Question Thread
Old May 3, 2011 | 09:37 PM
  #3766
MannyFresh's Avatar
Originally Posted by thescreensavers
I get 20.xx mpg pertank consistently, thats a little over 400 per tank.
Stop at 3k, give it some gas. If you been granny driving this whole time you need some time to learn
It's automatic
Old May 3, 2011 | 09:48 PM
  #3767
MannyFresh's Avatar
This weekend I'll be doing new spark plugs, k&n filter, spark plug wires, fresh oil and possibly a seafoam to clean the injectors etc etc
Old May 3, 2011 | 09:49 PM
  #3768
CG4DR's Avatar
Is there a difference in the tune between a coupe and a sedan? if so what is different? been looking at different mods and some say will work on coupe but not sedan....
Old May 3, 2011 | 09:57 PM
  #3769
thescreensavers's Avatar
Mr.202?
Originally Posted by MannyFresh
It's automatic
Ok? Mine is too what's the issue
Redline si-1 is better for cleaning fuel injectors then seafoam. Pepboys sell it
Old May 3, 2011 | 10:02 PM
  #3770
Mr.202?
Try a fabric glue
Thanks, do I pull it back and glue behind it? And were can i buy fabric glue, aap, Michals?
Originally Posted by StormTroopa
do you really use all 20 gallons? the most i've used was ~18.1
I usually fill uo between 16-17.5 gallons when i fill up, i am saying that's what i can get
Old May 3, 2011 | 10:54 PM
  #3771
CG4DR's Avatar
i think the car will shut off before you use 20 lol
Old May 3, 2011 | 11:03 PM
  #3772
jeovanni223's Avatar
does anyone know if the 06 z mid-pipe fit the 04 sedan?
Old May 4, 2011 | 12:16 AM
  #3773
Mr.202?
Nah, lol there is fuel in the lines, so you can probrally go more. Anyone have fuel line length and diameter? heh we could calculate how much fuel is in the lines + tank
You also have an issue though running the pump dry :O so I dont think Ill test it just saying.
Old May 4, 2011 | 12:17 AM
  #3774
Mr.202?
Yes and no, you need to get an 6inch extension pipe, other wise its a great upgrade make that epic signature sound live!
Coupe midpipe is a direct install.
Old May 4, 2011 | 12:19 AM
  #3775
CandlestickPark's Avatar
ill Sedan
The Z middy isn't a direct swap. You'll need add an extension to it (6 or 8" IIRC) to fit a Sedan or Coupe.
Old May 4, 2011 | 01:02 AM
  #3776
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by xxxxxxxxxx
Ok so i bought some headlights but they are halogen (h1 bulb) and i have the stock hids on my car (d2r bulb) so i was thinkin can i buy h1 hid bulbs , cut the wires from them , cut the wires from my stock d2r bulbs , and put them together so they work with the stock ballast, that way i have h1 hids. Would this work? I dont wanna go thru the mission in buying new ballast and all that stuff.
Ps. I know is gonna make the glare but w.e
That should work.
The glare actually shouldn't be all that bad.
Another option (really the 'right' way) would be to dismantle both the new headlights and your existing ones and swap the reflector assembly from the old ones into the new ones thus converting them to D2R style.
Oh, and if anyone is wondering, the housings are the same, as mine has something about D2R stamped in the plastic of the housing, despite the fact that they are OEM halogen (H1)
I've used 19.5 before.
I think you could get 20.
Danny...... you're now officially a dork
Old May 4, 2011 | 01:06 AM
  #3777
CG4DR's Avatar
i have a z middy and extension for sale. it will fit. i took it off bc i bought another exhaust.
Old May 4, 2011 | 01:42 AM
  #3778
MannyFresh's Avatar
[QUOTE=thescreensavers;5851166]Thanks, do I pull it back and glue behind it? And were can i buy fabric glue,
Just try to apply to the back of were it's pealing and you should be good. And I'm sure a walmart would sell that or a fabric store around your area.
Old May 4, 2011 | 01:43 AM
  #3779
MannyFresh's Avatar
Redline si-1 is better for cleaning fuel injectors then seafoam. Pepboys sell it[/QUOTE]
Thank you for that info will be buying that this weekend. Hopefully all this will help out.
Old May 4, 2011 | 03:05 AM
  #3780
xxxxxxxxxx's Avatar
[QUOTE=NFSP G35;5851555]That should work.
yeah i dont wanna open it and go thru that mission again,lol
but u think it would work if i do what i want to do?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
