Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Sep 24, 2011 | 01:26 PM
  #4861
thescreensavers's Avatar
Mr.202?
Brake shutter is back, at 45k I had my rotors resurfaced and pads sanded lightly. Everything was good until now (63k) its bad just slowing down on the highway. Bleh (OEM Pads at 32k) and I believe OEM Rotors that came with the car in 05.
Old Sep 25, 2011 | 08:41 PM
  #4862
Mr.202?
What sized sockets are needed to remove the Rotor?
To move the Piston over to get to the pads its 14mm(20ft lbs)? What MM to remove the Torque members to get the Caliper/Piston out of the way? What Torque setting should they be torqued back too?
Edit: Ok I got the torque Specs, Just need the sizes
Old Sep 25, 2011 | 08:58 PM
  #4863
NFSP G35's Avatar
? = 2B || !2B
They're different front and back.
I think the front is 22 and the back is either 19 or 20 IIRC
Old Sep 25, 2011 | 09:05 PM
  #4864
Mr.202?
^ yep its 22mm.
Thanks
Old Sep 25, 2011 | 09:53 PM
  #4865
Mr.202?
So I need to use Brake Cleaner (right? ) and a wire brush to clean off the old grease from the back of the pads, Shims and apply new grease.
What type of grease is best for this application?
Pad< Shims < Shim Cover
"<" = Where to apply Grease , I have to apply a thin layer and give it some time to dry so that it does not get pushed out.
Also I should clean the hub(where the rotor sits on) and the inside of the Rotor right? Do I put any grease here?
Old Sep 25, 2011 | 09:59 PM
  #4866
NFSP G35's Avatar
? = 2B || !2B
There's greases specific for brakes
Old Sep 25, 2011 | 10:02 PM
  #4867
Mr.202?
in bythebays video they used Synthetic Caliper Grease, I just wanted to know what you or what everyone was using.
They said not to use Brake Quiet or something like that?
Old Sep 25, 2011 | 10:33 PM
  #4868
NFSP G35's Avatar
? = 2B || !2B
^I used whatever they had in the little blister packs at O'Riley
Worked good though
Old Sep 25, 2011 | 10:57 PM
  #4869
Mr.202?
^ lol, was it this?
I have done some googling and that one is rubber safe and people at BITOG like it. They sell it at napa or at Autozone in the small packets, and O'Riley but we dont have them down here.
So what needs Lubin? #1 Sliding Pins, #10 Shims, .... ?
Old Sep 25, 2011 | 11:13 PM
  #4870
NFSP G35's Avatar
? = 2B || !2B
^Nah, it wasn't that one... I don't remember, but it was green I think.
I lubed absolutely EVERYTHING except the surface of the pad itself. Whole back of the pad, the edges where it snaps in, pins, all of it.
Old Sep 26, 2011 | 12:05 AM
  #4871
Mr.202?
k lol
Old Sep 26, 2011 | 12:03 PM
  #4872
VincenzG35's Avatar
Question I wanna buy either magnaflow muffler or the HKS will I pass emissions if I do?
Old Sep 26, 2011 | 12:22 PM
  #4873
davidxu's Avatar
no prob.
Old Sep 26, 2011 | 03:05 PM
  #4874
Mr.202?
For doing a brake fluid change with three people
Suck out old fluid and pour new fluid in- Have Person A watch fluid level
Get Person B and get them to hold the brake down.
Person C opens the bleeder bolt (10mm) with a plastic tube over it(anyone know what size? )
Then when no more fluid comes out, Tighten the bleeder then get Person B to pump the brakes while Person A makes sure fluid level stays good.
Then Start over again by loosening the bleeder.
Pump Pedal
Loosen Bleeder
Tighten Bleeder
Lift and start pumping.
Do this until clear fluid is coming out?
Old Sep 26, 2011 | 04:20 PM
  #4875
TurTLe*'s Avatar
^ person A is not needed. B or C can do job of A easily. Normally i'm person C and i walk and look after about 3-5 pumps. So B can just chill in the car.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
