Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Sep 29, 2011 | 09:55 PM
  #4891
ronniepetras's Avatar
It's your cats
Old Sep 29, 2011 | 10:06 PM
  #4892
3truman's Avatar
Its the hot cats cooling down, my car does not make that sound anymore..........those darn ART pipes lol
Old Sep 29, 2011 | 11:16 PM
  #4893
Wilg35j's Avatar
Haha thanks mistery solved
Old Sep 30, 2011 | 12:34 AM
  #4894
ilv2xlr8's Avatar
I'm driving on (4) 235/45-18 Conti DWs. I got a metal shard in one of them and it looks like I have a slow leak. (okay to drive on??) The tires have about 5-6K miles on them. Wearing pretty normally except very slight cupping on two tires (just rotated them.)
Will it be okay to put my spare on? It's a brand new 215/55-17 Conti DWS. The rolling diameters are the same new but will the tread difference screw with the AWD?
Old Sep 30, 2011 | 01:22 AM
  #4895
Alpha Phi's Avatar
What deep dish rims should I get and what color? My 03.5 sedans is brilliant silver
Old Sep 30, 2011 | 01:49 AM
  #4896
thescreensavers's Avatar
Mr.202?
I dont think the tread difference will matter, it matters about the Outer Diameter which you said is good.
Its fine to drive on a tire that has a slow leak just need to make sure you have air to put into it. Get it plugged when you can.
Old Sep 30, 2011 | 01:53 AM
  #4897
Alpha Phi's Avatar
What is the best all around springs you guys would suggest to drop a g35 sedan? I want coilovers but I am a college student on a tight budget.
Old Sep 30, 2011 | 10:23 AM
  #4898
Wilg35j's Avatar
H&r's give u a nice drop, they go for about 270-280.
This is how they look after settled with 19's
Old Sep 30, 2011 | 07:47 PM
  #4899
MannyFresh's Avatar
Bought a 5/16 plenum spacer, but no hardware was included. I know motordyne sells them for $45. But my question is do I need those white plastic tubes that go under the plenum?? What else do I need besides the extended bolts?
Old Sep 30, 2011 | 08:36 PM
  #4900
DR.D69's Avatar
if its the basic you need the actual machined spacer, the white (or black) plastic spacer gaskets that go on the bolts in the upper center, all the extended bolts (should be 18 of em), plus washers for all the bolts and a tube of red loctite. If you got the iso thermal kit then you also need the gasket and the coolant control valve.
Old Sep 30, 2011 | 09:44 PM
  #4901
MannyFresh's Avatar
I honestly dont know if its iso thermal kit or the basic.
I was in a bit of a hurry (stupid me) so he just gave me what he had only and told me all i need are the bolts.
Also i believe the spacer came off a 350z.
Here are some pictures of what he gave me and maybe someone here can help me out on what i need.
Old Sep 30, 2011 | 11:47 PM
  #4902
NFSP G35's Avatar
? = 2B || !2B
RLQ: What do ART pipes sound like on an otherwise stock exhaust?
Old Oct 1, 2011 | 12:00 AM
  #4903
ryanm8's Avatar
- Deeper and a little louder than stock cats when < 2.5k RPM
- Rasp from 2.5-3k
- Not much different > 3k since induction noise becomes louder than the exhaust noise
Old Oct 1, 2011 | 01:43 AM
  #4904
DR.D69's Avatar
I can't really tell whats in the bag but it is the basic kit as there is no iso-thermal manifold gasket. Should be fine if its off a 350z as its the same motor and the cut out looks the same. I'd get the parts kit and the iso thermal gasket. Here's a link to motordynes website or you can use one of the vendors on the site
http://www.motordyneengineering.com/index.php?cPath=1_5
hope this helps.
Old Oct 1, 2011 | 11:20 AM
  #4905
MannyFresh's Avatar
hope this helps.
This does help me out alot. Really do appreciate the help. thanks again.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
