Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Feb 4, 2012 | 10:12 PM
  #5611
CandlestickPark's Avatar
ill Sedan
Originally Posted by BlkSedan4me
they fit in the backseat. you just gotta put them on a sideways "69" position and be careful when you close the door so you dont scratch your door panels with the seat rails. maybe put a towel under the rails just to be safe.
Agreed they will barely fit in the back seat in the 69 position. Just be very careful of the seat rails, they will scratch/puncture your back seats, roof liner, door panel, etc. I used several towels and cardboard when I picked mine up and brought them home.
Old Feb 4, 2012 | 10:14 PM
  #5612
thescreensavers's Avatar
Mr.202?
Originally Posted by TurTLe*
link to one of these aftermarket internal ones?
I never knew/heard of such things.
Actually they might not be aftermarket internals, Link
You just need to match the FCC ID and it should be the same key.
Anyhow, my key is working again I got some Contact Cleaner, the stuff people use to clean Pots, It cleaned off the corrosion and now it works!
I tried it on my other key which died randomly, but it did not work on it, though it did clean up the corrosion on the PCB lol
So if your key stops working go get some Contact Cleaner and a nylon brush and see if that works before forking over 100 bucks to get a key and to program it.
Old Feb 4, 2012 | 10:57 PM
  #5613
TurTLe*'s Avatar
Originally Posted by ray1370
What I did was pull the backseat bottom out first, then let the coupe seats sit on the backseat floor facing front. I put flattened computer shipping boxes on the backseat floor to protect it from the coupe seat rails, and between coupe seat back and the backseat. Wrap the ends of coupe seat rails with towels, and be careful not to scratch your paint/trim when getting them in and out of your backseat. Each seat weighs about 50~60 lbs. Hope this helps.
You guys are tempting me to try this.
I would easily pull off the bottom cushion. I was thinking of taking off the pass seat. So i can mount the pass coupe seat in there. So all i have to deal with is the driver seat in the back seat somehow.
Sadly I have to travel about 120 miles for this. So it would **** me off if, i couldn't fit it in the backseat once i got there.
So when you speak of 69. Its exacly how 2 people would do 69 tradionally. Not sideways. I didn't think they could remotely fit because it looks like the door dont open that wide.
Old Feb 4, 2012 | 11:30 PM
  #5614
NFSP G35's Avatar
? = 2B || !2B
The 69 analogy is going way too far
Old Feb 4, 2012 | 11:36 PM
  #5615
ill Sedan
Mine fit in the "traditional 69" way, not sideways.
It would definitely be much easier to just go up there without a passenger seat and just bolt the passenger Coupe seat up and only have to put one seat in the back.
Old Feb 4, 2012 | 11:37 PM
  #5616
ill Sedan
LOL it has, but its totally applicable and relevant.
Old Feb 4, 2012 | 11:38 PM
  #5617
NFSP G35's Avatar
? = 2B || !2B
^ Oh yes, entirely true!
Old Feb 5, 2012 | 12:45 AM
  #5618
TurTLe*'s Avatar
yes and no, doing so would result in SRS light. While we have a DIY somewhere floating around, i've done it on pass nissans i've owned and it doesn't always work.
Plus i still have to stuff one seat in there. One person is coming with me because 50lb seat wedging is a lot easier with 2 bodies VS 1. I pulled out my maxima seat, not as heavy 35-40lb and it was annoying to get out by myself and not damage stuff.
My issue would be if he has it in the lean back position, i would need to power it up to fit better into the backseat.
Old Feb 5, 2012 | 02:02 AM
  #5619
NjMatteSedan's Avatar
Theres 2 auctions for 05-06 tails 1 for left and 1 for right, 150$ shipped each. Theyre both used in great condition. Whos gonna jump on that deal? NFSPG35 they got your name written all over em
Old Feb 5, 2012 | 02:12 AM
  #5620
Its not hard to fit thenlm back there. You just gotta move your front seats up some to give you more room. I drove 2 hrs back and forth to pick mine up. I went wirh a buddy you shoukd do the same so he can help you put em back there.
Old Feb 5, 2012 | 02:21 AM
  #5621
ryanm8's Avatar
What's the install like for these seats? Is it an easy direct swap?
Old Feb 5, 2012 | 02:38 AM
  #5622
Direct swap yes. To get the lower seats to work however requires modification
Old Feb 5, 2012 | 08:51 AM
  #5623
NFSP G35's Avatar
? = 2B || !2B
I wouldn't really say 'deal'
Not too bad, but I've seen individual lights go a little cheaper on eBay
Old Feb 5, 2012 | 11:08 AM
  #5624
ryanm8's Avatar
I'd wait also. I paid $100 at a local place for one of mine and $120 on Ebay for the other.
Old Feb 5, 2012 | 11:32 AM
  #5625
Most of the ones unfer 150 shipped have cosmetic damage of some sort. I wonder why the 2nd gen tails are so cheap on ebay they're like 80 each
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
