Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Feb 8, 2012 | 09:09 PM
  #5671
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by thescreensavers
Sure np.
You're awesome. Thanks a ton!
For everyone else info:
Danny's log shows that once he's up to temp, the car runs an average of 196deg peeking at around 201 when not moving.
Mine is running between 199 and 208, with it at 204 most of the time.
This is a little hotter than I'd like to see, but apparently the stock cooling system has a little higher temp that I was thinking it did anyway. (I thought it was more like 185-190)
Question now is, do I have a sensor that's incorrectly reporting the temp, a thermostat that's not opening at the right temp, a combination of the two, or another problem entirely.
Old Feb 8, 2012 | 10:50 PM
  #5672
Matzo Ball's Avatar
Originally Posted by Songle6MT
Even if they are balanced to 0 they can still cause vibrations....
Have you tried a high speed road force balance? I will never just do a normal balance again.
besides the high speed balance, what else is recommended. Should I have them balanced again?
Old Feb 10, 2012 | 08:50 AM
  #5673
sharkcityG's Avatar
Noob question, Will a Stillen Z tube fit on a JWT pop charger intake filter?
Old Feb 10, 2012 | 09:10 AM
  #5674
NjMatteSedan's Avatar
Yes
Old Feb 10, 2012 | 02:16 PM
  #5675
Ok im really confused with hubcentric spacers cause i see they come with built in studs already and holes for the other studs that are already on your car but im confused wouldnt the other stufs that dont go thru thr lug nutd hit the back of the wheel? The old non hubcentric spacers i used to have only had 5 holes not 10. And also im running longer studs not the oem studs which came with my old spacers. Would the hubcentric spacers still work with longer studs?. Old spacers were removed due to vibration, hence why i'm shopping for hubcentrics
Old Feb 10, 2012 | 02:56 PM
  #5676
Abax84's Avatar
If you already have extended lugs why not just stick with that and get a larger spacer? Stock lugs shouldnt hit the back of the wheels depending on your wheels themselves. I think the Rays for example have "pockets" in between where the lug threads that allows the stock lugs to sit in there. This isnt making sense, I need to find a pic.
Old Feb 10, 2012 | 02:58 PM
  #5677
Abax84's Avatar
Ignore the arrows, see the pockets in between where the lugs go? Thats where the stocks would sit if you ran the bolt on spacer, but again with extended lugs who knows, depends on the length of the stud probably. And some wheels wont have those pockets at all.
Old Feb 10, 2012 | 03:27 PM
  #5678
g35_white's Avatar
is 700-800 rpm a good enough idle range when at signals? i noticed once the engine warms up, the idle rpm is 700-800 rpm. shouldn't it be 1k rpm? is this normal?
Old Feb 10, 2012 | 03:30 PM
  #5679
TORETTO's Avatar
Sounds normal to me...
Old Feb 10, 2012 | 03:59 PM
  #5680
TurTLe*'s Avatar
Yes, they go between the lug holes. OEM wheels have those gaps should be good for least 20mm, some aftermarkets have them.
Old Feb 10, 2012 | 05:38 PM
  #5681
thescreensavers's Avatar
Mr.202?
Warm idle is ~650 but if you have the AC on or radio
.etc it raises idle
Old Feb 10, 2012 | 05:46 PM
  #5682
ryanm8's Avatar
.etc it raises idle
Shouldn't be more than 700 even with AC/radio on.
Old Feb 10, 2012 | 05:47 PM
  #5683
g35_white's Avatar
.etc it raises idle
Well its around 650-700 without a.c. its basically two lines shy of 1k. thanks for the info though.
Old Feb 10, 2012 | 05:54 PM
  #5684
CG4DR's Avatar
I sit just below 500 rpms with a/c off.
Old Feb 10, 2012 | 05:58 PM
  #5685
CG4DR's Avatar
Originally Posted by g35nit
I have 6k bulbs running the projectors. Is there a way to adjust the cut off point?
Most aftermarket products don't come with glare shields (HIDs) and or cut off (projectors, if aftermarket) so it may be a combination of both or just the HIDs since there is most likely no glare shield
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
