Random Little Question Thread
I was looking to purchase some oem brembos when I came across this:
http://www.ebay.com/itm/Big-Brake-Ki...87d3d7&vxp=mtr
It uses the stock 2006 rotors so I could run a stoptech front and rear rotor kit. I've done alittle research but no real reviews of it. I know its not a factory wilwood kit but it seems like a cheap alternative. Just trying to see what you guys think about it.
Brought it out to the shop today to get the wiring checked out and everything seems fine. Found out that my high tone horn was out of commission, possibly why my fuse keeps going bad. Ill find out soon enough once I replace the horn. Maybe i should upgrade the horns while Im at it since ill have to replace one anyways...
Quick question for you guys, I'm buying this z tube off kijiji but it doesn't look like the traditional z tube. He said it's from an 07 350z. Question is: will these work? I have an 04 g35 sedan.
Here's the z tube in question:
http://a3.sphotos.ak.fbcdn.net/hphot...20242339_o.jpg
This is what you need:
http://auto.badtziscool.com/wp-conte...icture-002.jpg
You can get Stillen's Ztube or an OEM for your 1st gen.
hey everyone, im looking to replace my oem air intake for some aftermarket ones. I got an 03 G sedan (doggy door) and I have no clue where to start. Any suggestions for this mod? Whats the ideal setup for this?
the only suggestion I have is if you're going to go with a new intake at least get a full CAI, meaning it snakes all the to the front of the car, a lot of people do short ram with no heat shield and suck in hot engine air. sooo either Z-tube/pop charger(w/ heat shield) combo or a full CAI. from what I hear, the OEM box with a K&N drop in and a Z-Tube is a pretty legit combo as well...
To be honest would have just kept my oem but when i bought the car the oem box was missing a component and right now the box is open and its not concealed. So i figured might as well go with aftermarket. I was thinking with the whole short ram with heat shield, z-tube/pop charger but im not sure which brand is prefer for the G
For reference
Round MAF
Rectangular MAF
I don't know about the 08 Nismos but when I changed out the endlinks on my 03 sedan, I purchased OEM 05 coupe sport endlinks as they are beefier than the OEM 03s. Another option you may want to consider
