Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jan 29, 2012 | 02:18 PM
  #5521
NFSP G35's Avatar
? = 2B || !2B
My carpc will take about 80w max.
55w vs 35w is 80w extra total (20w per bulb x 2 sides, x 2 per side, high/low and fogs)
But my mono amp isn't that big, I think it's like 3XX? W/RMS
Old Jan 29, 2012 | 03:10 PM
  #5522
CG4DR's Avatar
With the HIDs I believe it converts the power inside the ballast so you aren't technically having to generate any extra power. It's just taking the +V in and converting it to put out 55w which would be the same V consumption as the 35w
Old Jan 29, 2012 | 03:19 PM
  #5523
NFSP G35's Avatar
? = 2B || !2B
You can't make power out of thin air. Usually, HIDs are rated by how much they draw, a 35w draws 35w and outputs as much light as a 55w halogen, even though it doesn't actually output all 35w it draws from the electrical system into the bulb. (there is always loss when you convert power like a HID ballast does)
A 55w HID still draws more power from the electrical system than a 35w.
Old Jan 29, 2012 | 03:24 PM
  #5524
ryanm8's Avatar
You're fine. I have 2 12's which draw a max of 800w and I've never had the lights flicker or anything.
Old Jan 29, 2012 | 03:27 PM
  #5525
NFSP G35's Avatar
? = 2B || !2B
Hopefully. I guess I'm just used to my Trans Am that had a 160A alternator, so I never had to worry about it (plus, I could jump start a diesel )
Old Jan 29, 2012 | 05:46 PM
  #5526
CG4DR's Avatar
This guy.. smh
Old Jan 29, 2012 | 06:54 PM
  #5527
NFSP G35's Avatar
? = 2B || !2B
Need moar POWAAAAA!!!!
Old Jan 29, 2012 | 07:15 PM
  #5528
NFSP G35's Avatar
? = 2B || !2B
So, I'm about to do a drain/fill on the transmission... should I go with Mobile1 Synthetic ATF (compatible/exceeds Nissan specs) or Nissan Matic-S ????
And is Matic-S synthetic???
Old Jan 29, 2012 | 08:45 PM
  #5529
CG4DR's Avatar
go with the one that lubes the tranny the best.........
Old Jan 29, 2012 | 08:47 PM
  #5530
CG4DR's Avatar
so in a half failed donut with traction off, my slip light came on and stayed on and only 1 tire was spinning faster.. does the traction not fully disable or do i have an issue?? don't the 05 6mt have vlsd?
Old Jan 29, 2012 | 09:18 PM
  #5531
NFSP G35's Avatar
? = 2B || !2B
You have a manual, you're not allowed to have an opinion
Is it on the front or back?
Old Jan 29, 2012 | 09:22 PM
  #5532
Wilg35j's Avatar
You should know only to use matic s on the tranny
Old Jan 29, 2012 | 09:24 PM
  #5533
NFSP G35's Avatar
? = 2B || !2B
Do you have a tangible reason for saying that?
I've seen several people run other fluids in the Nissan transmission and claim to have no trouble...
Old Jan 29, 2012 | 09:29 PM
  #5534
Wilg35j's Avatar
A few people here have used diferent oils, and noticed that the car wasnt shifting right and have went back to matic s and the problem stoped.
Old Jan 29, 2012 | 09:37 PM
  #5535
thescreensavers's Avatar
Mr.202?
^ yep, the main reason Id never try anything different. Fluid is cheap in respect to how much the transmission costs.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
