Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jan 31, 2012 | 01:22 AM
  #5551
Trickstyle's Avatar
Originally Posted by NFSP G35
^Forgetting the projector retrofit? My car looks much different than your average G35 when running headlights only
I want... lol
Old Jan 31, 2012 | 07:52 AM
  #5552
superG-coupe's Avatar
what would happen if you only replaced one cat with a test pipe
Old Jan 31, 2012 | 09:28 AM
  #5553
jdubin94's Avatar
Impression in the Leather..
Ok.. So I had the arm rest down in the rear seat for about two weeks. When I lifted it up, there was a pretty bad impression from the lower part of the seat belt that was under the armrest... Will this go away? It looks pretty bad
Old Jan 31, 2012 | 06:51 PM
  #5554
NFSP G35's Avatar
? = 2B || !2B
Well, whichever side you replace, that side is going to have slightly more power and thus cause the car to pull toward the other side, so you're probably better to replace the Driver's side, so that if anything, your car pulls to the right instead of into oncoming traffic...
Maaaybe... Your best bet would be to soak it down in a good leather conditioner like Lexol, and let it sit in the hot sun for a while, repeat as needed.
Old Jan 31, 2012 | 10:21 PM
  #5555
TORETTO's Avatar
Or have individually controlled cutouts on each side, that way you can turn your car by switching cutouts.
Just like those military tanks.....
Old Jan 31, 2012 | 10:40 PM
  #5556
JaE35's Avatar
Moderator
G35 Sedan
My brembos want bigger rotors...what's the largest i can get for the oem brembos?
Old Feb 1, 2012 | 05:56 AM
  #5557
Herbbie Hablib's Avatar
Is the ester also recommended for the Rev-up motor or is it only recommended for HR and later motors?
Thanks!
Old Feb 1, 2012 | 12:31 PM
  #5558
thescreensavers's Avatar
Mr.202?
Thanks!
Don't waste your money, it shears quickly and not worth the money
Old Feb 1, 2012 | 01:41 PM
  #5559
G35Papa's Avatar
Is there a "Look what I want" thread?
Old Feb 1, 2012 | 02:14 PM
  #5560
CG4DR's Avatar
coupes are eww.. fastbacks only..
Old Feb 1, 2012 | 08:11 PM
  #5561
Ramanl's Avatar
Im thinking about getting 8000k headlights. D2R is the size. When I buy new HID lights, i just have to buy replacment bulbs right? my current 4300k stock still work, just looking to switch temps.
And how do you replace the bulbs in g35 headlights. Do I have to pull the bumper forward and unscrew the whole headlight?
Old Feb 1, 2012 | 09:58 PM
  #5562
NFSP G35's Avatar
? = 2B || !2B
^I wouldn't go over 6000k if I were you.
You can either pull the bumper and take the lights out, or access the back of them through the fender by taking the front part of the wheel well liner loose.
Old Feb 1, 2012 | 10:49 PM
  #5563
Trickstyle's Avatar
yep, remove bumper, unscrew headlights, just a bulb replacement.
if you do your fogs just add a ballast n HID bulb and if you got a decent kit, it should be plug n play...
Old Feb 1, 2012 | 10:55 PM
  #5564
Trickstyle's Avatar
Thanks!
After reading this I realized that the Rev-up and HR aren't interchangeable... can anyone fix my confusion? Is this(below) correct? Anything significant I'm missing?! kinda feel like an idiot right now lol
Rev-Up: 7.1k b4 redline, More HP than non rev-up?
HR: dual intake, More HP than DE?
Old Feb 1, 2012 | 11:13 PM
  #5565
Songle6MT's Avatar
Those are both sick.
No they are not interchangeable.
The regular DE motor and Rev-up are very very similar but have a few differences. Allowing different rev limit a little more power but less torque. Also I believe thier timing cover is a little different in between them.
The HR motor is the dual intake motor and more horsepower than both of the DE motors. It is a very different in many aspects.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
