Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jan 22, 2012 | 03:44 PM
  #5476
Matzo Ball's Avatar
Originally Posted by NFSP G35
1) I put them all on, but if I know I'm going to be taking the bumper off again soon, I'll only put in 2-4
2) Not exactly sure which screw you're talking about
3) None spring to mind
There are two bolts on each side on the inside of the bumper by the turn signals. I am referring to the inner most one.
Also what is the best way to remove winter grime/oxidation build up from polished lips?
Old Jan 22, 2012 | 03:50 PM
  #5477
NFSP G35's Avatar
? = 2B || !2B
^Those attach to the fender.
They should screw into a little plastic clip.
They're easy to get stripped out after a while too. I ended up ditching the plastic clips and just zip-tying them.
To remove them usually takes an extension or two for the one that tucks up underneath.
Old Jan 22, 2012 | 04:02 PM
  #5478
Matzo Ball's Avatar
zip tie is a good idea....and easier to remove
Old Jan 22, 2012 | 09:37 PM
  #5479
colinhuemmer's Avatar
I just installed my Hotchkis rear sway bar, and when i was getting done and tightening up the rear driver side end link bolt i noticed that it appears to be longer than the other end link bolt (the bolt that goes thru the sway bar) Does any1 know if this is normal or odd?? BTW im using Stock end links
Old Jan 23, 2012 | 10:50 AM
  #5480
Abax84's Avatar
Has anyone used their stock rear springs and G/Z front springs? My stock rears sat pretty low, probably 2 fingers at most. The car is going to my wife, so I need to bring it back up a bit, but Z suspension looks to be about as low as the Eibach springs on there now, so I thought maybe Z front and stock rear?
Old Jan 23, 2012 | 10:59 AM
  #5481
NFSP G35's Avatar
? = 2B || !2B
It would probably be excessively "raked"
Maybe not if you use stock coupe springs for the front, but that's hardly going to change your ride height at all and probably isn't worth the effort.
Old Jan 23, 2012 | 11:13 AM
  #5482
Abax84's Avatar
^ I just have to get the car raised back up but since it still has rims and all the goodies Ive done the last couple years, I would hate to go back to stock ride height. I just want enough room for her to clear driveways and speed bumps. Youre on full Z susp arent you?
Old Jan 23, 2012 | 11:27 AM
  #5483
NFSP G35's Avatar
? = 2B || !2B
^yes.
Old Jan 23, 2012 | 11:30 AM
  #5484
Abax84's Avatar
Can you compare it to the Eibach Pro Kit? Height wise?
Old Jan 23, 2012 | 11:35 AM
  #5485
NFSP G35's Avatar
? = 2B || !2B
Nope! Sorry.
Old Jan 23, 2012 | 11:37 AM
  #5486
Abax84's Avatar
It's fairly easy to change out rear springs isn't it? I could always just get the Z springs in and find some coupe rears later I guess.
Old Jan 23, 2012 | 11:43 AM
  #5487
NFSP G35's Avatar
? = 2B || !2B
The rear springs aren't too bad
Old Jan 23, 2012 | 11:52 AM
  #5488
Abax84's Avatar
^Thanks, haha never takes you more than 5 minutes to respond in this thread
Old Jan 23, 2012 | 03:04 PM
  #5489
NjMatteSedan's Avatar
You can always do the z springs up front and if it looks raked do the spring mount mod in the rear, that will drop the rear half an inch. And if it still looks raked get a couple subs in the trunk lol
Old Jan 23, 2012 | 03:26 PM
  #5490
Abax84's Avatar
how complicated is the spring mount mod? I havent looked into it much. Im trying to just get the car somewhere between stock height, and my Eibachs.. sooooooo .5" drop or so
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
