Random Little Question Thread
Oct 1, 2011 | 12:24 PM
  #4906
Is it normal for the igniter's to act kinda springy when putting them back in with new plugs?
I just did one bank, and 2 of them acted like that.
Reply 0
Oct 1, 2011 | 01:09 PM
  #4907
igniter's .... what is that? Igntion coils ?
if so yes they should have a little springy feel to them.
Reply 0
Oct 1, 2011 | 03:03 PM
  #4908
Quote: This does help me out alot. Really do appreciate the help. thanks again.
Your welcome haha...there is a button for thanks...haha just messin good luck with the install its pretty straight forward just make sure the car sat overnight makes it easy.
Reply 0
Oct 1, 2011 | 03:40 PM
  #4909
haha, exactly
Reply 0
Oct 1, 2011 | 07:46 PM
  #4910
will a clay bar decrease the fade of the color or just remove build?
Reply 0
Oct 2, 2011 | 12:47 AM
  #4911
^ "just remove build" , they mainly clean stuff off the paint. But ive seen shitty paint jobs that claying will remove COLOR off the car.
Reply 0
Oct 2, 2011 | 01:13 AM
  #4912
^ Clay Bar is only for use on clearcoated surfaced. If the clearcoat is pealing then dont use it. Only way it will take color off our cars if the clear coat is damaged. But you should notice it right away on the clay as it will turn (the color of your car)
on a side note
Oil Change, Brake Fluid Flush, Front Brake Re-lube, Spark Plugs, New stabilizer bar Endlinks left and Right - Complete!
Car feels amazing, but dreaded clanking sound over bumps remains
here are how my plugs(driver side Bank) look at 64k
Not bad but, they have been replaced
Reply 0
Oct 2, 2011 | 01:34 PM
  #4913
^Nah, those aren't bad... Did you see the pics of mine after 125k?
Reply 0
Oct 2, 2011 | 03:05 PM
  #4914
Quick noob question.
Does the 05-06 sedan front bumper fit on 03-04 sedans without any modifications?
Reply 0
Oct 2, 2011 | 03:06 PM
  #4915
Nope. sorry
Reply 0
Oct 2, 2011 | 03:41 PM
  #4916
Quote: ^Nah, those aren't bad... Did you see the pics of mine after 125k?
Just saw, damn lol. Did you notice anything? I think I feel a bit more low end power, though that might be because of the ECU reset.
Reply 0
Oct 2, 2011 | 04:43 PM
  #4917
Quote: Nope. sorry
dammit. thanks
Reply 0
Oct 2, 2011 | 05:31 PM
  #4918
How can I tell if my 03 g35 sedan came with oem HIDs?
Both lights are different. Left light isn't oem and is chrome and doesn't have the ballast while the right light is oem and does have the ballast.
Reply 0
Oct 2, 2011 | 05:40 PM
  #4919
^ the right is HID the other is not. If it has one OEM HID light in it then it came with OEM HIDs. The car was hit and they cheaped out and put an ebay light in the other side.
Reply 0
Oct 2, 2011 | 07:18 PM
  #4920
That's what I was thinking but I just wanna be sure.
Regardless previous owner put after market HIDs but I'm in the process of getting new headlights.
So it doesn't matter if I get regular headlights meaning no ballast?
Reply 0
