Random Little Question Thread
#5686
Most aftermarket products don't come with glare shields (HIDs) and or cut off (projectors, if aftermarket) so it may be a combination of both or just the HIDs since there is most likely no glare shield
#5689
#5690
another question, there is a good deal for maxiscan obdii diagonistic tool going on. i am wondering is it compatible with 2005 g35 sedan? i mean will this be used to read error codes for any lights that come up on dash?
here is the one i am talking about: http://www.amazon.com/dp/B001LHVOVK/...alsofamer05-20
Just my .02
g35_white (02-11-2012)
#5693
As it pertains to the questions in this thread - if you are idling between the first and second large dashes (500-1K rpm) you are fine - remember, it could be off by 100-200 rpm.
#5694
Ok im really confused with hubcentric spacers cause i see they come with built in studs already and holes for the other studs that are already on your car but im confused wouldnt the other stufs that dont go thru thr lug nutd hit the back of the wheel? The old non hubcentric spacers i used to have only had 5 holes not 10. And also im running longer studs not the oem studs which came with my old spacers. Would the hubcentric spacers still work with longer studs?. Old spacers were removed due to vibration, hence why i'm shopping for hubcentrics
The lug holes arent relevant with hub-centric. But the do have "lug centric" - which is the same thing but lug holes are centered.
If the hub is centered and you have proper conical lug nuts (which will center to lug holes) - you will be fine. If your spacer is not hub centric - the rings are cheap.
#5695
If you already have extended lugs why not just stick with that and get a larger spacer? Stock lugs shouldnt hit the back of the wheels depending on your wheels themselves. I think the Rays for example have "pockets" in between where the lug threads that allows the stock lugs to sit in there. This isnt making sense, I need to find a pic.
NjMatteSedan (02-12-2012)
#5698
Tuner's Random Question:
Did the 2006 Sedan offer a Projector? I have heard conflicting answers on this. I always thought the answer was NO, but there seem to be a few guys who swear they did briefly offer projectors on the 06 year. Obviously it may be guys that have SEEN projectors on an '06 that were retrofitted, but I am curious on this one. Nissan is known to introduce next-model items in the last bit of production of the old models, so I can't say it's not possible.
#5699
Have you guys been to this site for wheels. Holy crap they have some sick stuff. Unfortunately I cant get their 3d car example to work for my car. Wierd because I know some of the wheels there will fit our cars.
http://www.ozracing.com/car_wheels_b...%20Racing.aspx
#5700
