Random Little Question Thread
#6377
Need some advice, have ~2000 for mod money. I'm considering purchasing flawless condition 350z track edition rays powdercoated gunmetal without tires for 1000. Add in tires and that's 1700. Would you guys get cheaper rims (like coupe 18s) and have money for other things, or would you buy the rims? Thanks
#6379
As a track wheel owner its a much more rare set of wheels. Everyone is rocking coupe 19's and well coupe 18's just look like stock wheels to me. I got my track wheel set because they were lightweight RAYs and i got them for a good price. If i had to do it again i would of gone with something different then what we are used to seeing on this board. Everyone here has EVERY SET of volks made, new and used. I would go outside of that circle but i realize you have a $2k budget. $1000 for a set of track editions is a little high for me, $650-700 for a set of coupe 19's are bad for what you get but like i said EVERYONE has them.
I personally like that type of wheels, if it was free I'd get TE37's =)
#6380
Coworker of mine got some two sets of Rotora BBK's from a Civic. 4 pot I believe but it's a possibility that it's a 6. I have to confirm. Wondering if I get brackets for them, would they fit the G? Also, worth it over stock brakes? And lastly, possible to use one front for the fronts and the other front for my rears? I'm not concerned about whether it's worth buying them because if I did buy them, it would probably be for dirt cheap, by dirt cheap I mean nearly free.
If that size is smaller than stock size, or if the width is far-off, then they're no good to you at all.
You've also got to factor in the cost of precisely machinging the adaptor brackets, they'll be one-off custom pieces, they have to be made from High-Strength steel that's rated for High-Torque/load applications like that. None of this is cheap, by any stretch of the imagination.
And the short answer for the rear: No, they won't work.
So my recommendation, is if you're gettina smoking deal on them, get them and sell them. Take that profit and put it towards an upgrade that's made for the 350z/g35
The headache of having one-off custom Wear items is huge. Even after yo'ure done the custom work, your headaches are just beginning. Custom parts are awesome, bragging rights and uniqueness is too, but on a wear item, on a DD, it's silly, IMHO
There's places to do it, but brakes aren't one of those places.
The Stimulation (05-26-2012)
#6381
Basically, you CAN make almost any BBK caliper work. The biggest thing you need to know is the rotor size that they're designed for, both width and O.D.
#6382
I've owned 3 sets of track editions. And kept the 5 rears 18x8.5 that were clean.
#6383
OK this is ridiculous! So a few weeks ago my horn stopped working and i brought it into a shop and they found out the fuse was no good, so the fuse got replaced. After work today, i knew my horn was working because i had to honk at some guy that almost backed up into my car. When i arrived home and went to lock the car, there was no horn! Would you guys know why my horn fuse keep going bad? maybe upgrade to hella horns while im at it since the guy barely heard my car!
#6384
#6385
Maybe the honk circuit works but when you hit LOCK and the horn triggers that, that circuit is bad causing the fuse to break. Most likely something in the lines but it could be horn related.
Anyone shop should be able to take care of this as it sounds like a very simple short to ground.
#6386
They are the poor man TE's ill give you that. I do like them, it adds a little OEM+ taste to my sedan. At a glance people assume just stock wheels, only G/Z guys know what i have. Rarely do people see the "ray's" on the wheel.
#6389
TunerMax (05-27-2012)
#6390
