Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #6316
Old 05-15-2012, 10:49 PM
TheGThirty5's Avatar
Originally Posted by Trickstyle
u try sanding em down? like with a 3M oxidation removal kit?
Edit: I dont know if it will work or do anything but it looks like it maybe could? depends how deep the cracks are i guess...
I havn't tried sanding them down yet but maybe will give
It a try but they are pretty bad thanks for the tip
  #6317
Old 05-15-2012, 11:31 PM
Theory_EK's Avatar
Originally Posted by DVG
Looks like 03 to me. I tell the difference from the flourishes on the circles.
Pics related.
That's why I'm confused because the bumper looks as to fit with no gaps.
  #6318
Old 05-15-2012, 11:38 PM
WhipWhitaker's Avatar
^ def. not a Nissan factory product, and not 03 because it would have little grooves in front of the turn signal. I would guess it was bought on ebay as a blacked out housing headlight.
  #6319
Old 05-15-2012, 11:51 PM
This was my first thought as well. It doesn't look promising as you mentioned that they're burned but it's worth a shot since headlight restoration kits are usually around $20.
  #6320
Old 05-16-2012, 12:03 AM
Kingd's Avatar
can someone help me answer this question? I have an 03 sedan with the doggie door on the trunk; my question is can i replace this trunk with newer oem sedan trunk (maybe 04,05,06)? Maybe its worth my time just to get an aftermarket trunk?
  #6321
Old 05-16-2012, 12:37 AM
NFSP G35's Avatar
? = 2B || !2B
^Yes. Trunks are fully interchangeable.
Note, that without the doggy door, you're limited to your keyfob for opening the trunk.
You could, in theory, route the wires up to the dash somewhere and install a button if you wanted to. It'll be pretty obvious when you switch to the decklid without the handle that there's an extra pair of wires that used to go to the button in the handle.
  #6322
Old 05-16-2012, 12:51 AM
TunerMax's Avatar
Below are my thoughts as well:
Looks like an Ebay 03/04 headlight that was installed in the 05/06. From the pics you cannot tell for sure either way, about fitment or the headlight because it's aftermarket.
03/04 is cheaper, even in the knock-off form, and from the look of that grill, etc, cheap is the route this guy went with the car
Thought all 03.5 and 04's were this way though, we don't have a button on the exterior, just the key fab. And the trunk release button inside the cabin. The only mechanical over-ride is the pull handle inside the trunk, that can be reached through the ski-pass with some dinking around.
That being the case, deleting the doggy-door is in effect just the same as a normal 03.5/04 set up. Unless i"m missing something
  #6323
Kingd's Avatar
Good to know that it can be interchangeable, however you did raise a good point about relying on the keyfob to open the trunk. This could be problematic one day if i do decide to change it hrmmm
  #6324
Old 05-16-2012, 12:56 AM
NFSP G35's Avatar
? = 2B || !2B
And there is the difference
03.0 doesn't have a button in-cabin. Just the handle on the trunk and the button on the remote.
KingD, I wouldn't worry about it too much. It's plenty easy to use your keyfob, as you keep it on your person most of the time anyway.
And if you're worried about locking yourself out of the trunk, there are actually two manual overrides.
1) the glow-in-the-dark handle near the back
2) small black pull tab that will be very close to the pass-thru door when the trunk is shut. It's Velcro'd to the center/forward-edge of the decklid
TunerMax (05-16-2012)
  #6325
Kingd's Avatar
wait a sec theres a button inside the car to open the trunk on the 3.0 sedan? Sorry for the stupid question, ive only owned this car for 2 weeks
  #6326
Old 05-16-2012, 01:00 AM
NFSP G35's Avatar
? = 2B || !2B
^Nope, read my comment above
  #6327
Old 05-16-2012, 01:03 AM
Kingd's Avatar
ops, i saw it after i post it, but i couldnt figure out how to delete it
  #6328
Old 05-16-2012, 01:07 AM
TunerMax's Avatar
Problem/solution!
Thanks NFSP for clearing that up.
I suppose that makes sense for them NOT to have the in-cabin switch if there's a handle on the back.
  #6329
Old 05-16-2012, 01:09 AM
Kingd's Avatar
This is awesome to know, for some reason I have a problem with the look of the trunk. I rather have the newer trunk for a clean smooth look (in my opinion anyways)
  #6330
Old 05-16-2012, 01:14 AM
NFSP G35's Avatar
? = 2B || !2B
^You mean like:
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
