Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #7816
Old 12-02-2012, 12:10 PM
JFletch's Avatar
Alright I need anyone with an opinion to post. I know the general rule of thumb is cleaner the better or less is more buy I was thinking about doing a subtle pinstripe with the Tommy Kaira logo in it towards the rear. I have an '03 silver sedan with some mods and I am planning on getting some more TK products in the near future. What are your opinions on this?
  #7817
Old 12-02-2012, 12:35 PM
TunerMax's Avatar
I'm gonna blasphemise and say how much i hate Tommy Kaira. Ridiculously overpriced ricey crap. He used to do good things but that was a long time ago, since he got big he is doing nothing but tasteless stuff.
/blasphemy
  #7818
Old 12-02-2012, 02:57 PM
canehdian_guy's Avatar
Originally Posted by TunerMax
There's no right answer to your question dude.
Firstly, if you're looking for performance, 19" rims are NOT the way to go.
Secondly, performance can mean straight line, auto-x, road course, or just spirited street driving. All of these have different tire/rim requirements, but no matter what you do, a bigger diameter rim will always hurt your performance.
Thanks TunerMax. I realize it's not optimal for performance but I don't want to go any lower then 19's, just hoping to find the most reasonably 19" setup for me.
As for performance goes I would fall into the straight line/spirited street driving category. With that sort of driving style what would be a good staggered set up to run? Measurements would be appreciated.
And do you feel it would be fairly disadvantageous to run 9.5" in both the front and back but with wider tires in the rear like on the first G35 models?
Thanks
  #7819
Old 12-02-2012, 07:02 PM
Muney2bmade's Avatar
Lowering your G35
Is it bad for you car?
I'm assuming it's not because I think pretty much 85% of everyone on here has theirs lowered.... and I was gonna do it myself, but a guy at my work was like
"Infiniti spent thousands of hours perfecting it, not for you to go in there and F*Ck up the suspension"
so it made me think a little.
Anyways, saw this last night, unique.
  #7820
Old 12-02-2012, 07:18 PM
350GT_'s Avatar
When you lower your car you're throwing off all of the other components in the suspension which may cause other parts to wear out quicker such as your tires, axles, and bushings. A lot of people out there put aftermarket suspension on their performance cars that already come equipped with performance or racing suspension. But clearly our factory suspension differs from that of, say, Lotus since our cars aren't built for racing/track use. Anyway, if you lower your car you'll likely throw off your alignment which will cause your tires to wear unevenly and prematurely. Of course all of that can be corrected with the use of camber kits.
Anyway, use the search function on here. That's what many others will likely tell you. It helps a lot, and many of the questions you have may have already been answered.
Check out these links:
https://g35driver.com/forums/g35-cou...d-threads.html
https://g35driver.com/forums/brakes-...w-updates.html
The second one is one that will help you out with suspension and lowering.
  #7821
Old 12-02-2012, 07:20 PM
beriously's Avatar
What color paint is this?
Does anyone know?
  #7822
Old 12-02-2012, 07:31 PM
partyman66's Avatar
Blue?
The factory red color that G35's use is called Laser Red. I'm not sure if that color matches the factory Laser Red or not.
  #7823
beriously's Avatar
Originally Posted by partyman66
Blue?
._. I know it's red but is it a certain type of red?
  #7824
Old 12-02-2012, 07:38 PM
Beebo's Avatar
Thats Law's car, ill see if i can find his build thread to find out the color but i think he deleted the thread
brb
  #7825
Old 12-02-2012, 08:57 PM
beriously's Avatar
brb
you find out yet?
  #7826
Old 12-02-2012, 10:05 PM
Anyone know if these rims will fit my current tires + car?
http://www.ebay.com/itm/INFINITI-G35...3c0018&vxp=mtr
I have an 06 base coupe, with the base rims.
  #7827
Old 12-03-2012, 05:12 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
They'll fit but with an offset of +45 they will be very sunk in. You'd be better off looking for the 18" version (looks identical) that was made for the coupe.
  #7828
Old 12-03-2012, 10:08 AM
JFletch's Avatar
I was researching replacement options for my stock compression rod bushings when I stumbled across Battle Version adjestable caster arms. Are the the same thing because they look almost identical?
  #7829
Old 12-03-2012, 03:26 PM
MrTBahgs's Avatar
Last week i ended up barely hitting the hitch on an SUV and it cracked my front grill assembly and also slightly dented the tip of my hood (06 G35X). I havent been able to get an estimate yet for the fix, but I was looking into other options on the side.
First off i figure I can replace the grill assembly myself and after a lot of searching I was finally able to track down the right part number for the grill (62070-A700). I am curious if only the 05-06 grill will fit or if the previous model will fit as well, im unsure what all is different for the front ends. If I try going to a U-Pull-It for a used part rather than order new, what are some easy tricks to finding out the year of the G's they might have besides the tailight design, (VIN or other fool proof places to check)?
Secondly, if I end up finding the cost of the hood to be near the same price as a new one (if paint is involved) has there been many experiences with aftermarket hoods and how perfectly they fit? Im not sure what to look for in an aftermarket hood as far as material goes, but it would open the option for a carbon fiber one as well. What is the realistic price for a quality CF hood because i've seen some for as little as $500 and that just seems extremely low and wouldnt want one that is flimsy or peels after a year. Same thing goes for the hood, I assume the 05-06 sedan is a unique shape and only those years will fit.
Any comments on your experience with aftermarket grills (billet or other) and hoods in general will also be appreciated.
TYIA
  #7830
Old 12-03-2012, 03:40 PM
3truman's Avatar
For the grill you will need an 05-06 either factory or ionic emblemless, you could do billet but its a played out trend that most on here discourage, but its your car do what you want. as far as aftermarket hoods go, i dont think anyone has made anything except a custom one off hood, i dont remember what member has it but i think hes the only 05-06 with a custom hood.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
