Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #7291
Old 09-25-2012, 05:49 PM
MrTBahgs's Avatar
I know the coupe mid pipe is the correct length for the sedans to just be swapped in, but is the 03/04 coupe mid much different than the 05/06? I guess from both a look/fitment stand point as well as sound.
This would be for an 06 G35X just to be sure they both would fit fine as well.
  #7292
Old 09-25-2012, 07:06 PM
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by DVG
Im probably going to have a closer look at brew_hahas swap thread tonight
Don't forget, he's using an LS-based Iron block motor, not all aluminum.
  #7293
Old 09-25-2012, 07:12 PM
WILLIE BEANS's Avatar
quick question ..which would you say are better
rear sway bar end links:
SPL vs WHITELINE
after looking at both .
the SPL bearing look beefier than the whiteline ..
your thoughts ??
  #7294
Old 09-25-2012, 07:26 PM
g35_white's Avatar
is it ok if i use Valvoline ATF Dexron III capable fluid to change power steering fluid in 05 g35 sedan or should i get ATF fluid from dealership?
Thanks
  #7295
Old 09-25-2012, 10:54 PM
MPG35fiend's Avatar
CHOOSE ONE.
Air Ride Suspension or BBK?
  #7296
Old 09-25-2012, 10:56 PM
TORETTO's Avatar
Received 1,939 Likes on 1,249 Posts
heres one
big brake air ride suspension kit bundle
  #7297
Old 09-25-2012, 10:57 PM
NFSP G35's Avatar
? = 2B || !2B
bbk
MPG35fiend (09-25-2012)
  #7298
MPG35fiend's Avatar
im down!!!!!!! for the right price....
  #7299
Old 09-25-2012, 10:58 PM
MPG35fiend's Avatar
leaning towards BBK as well... want Akes powder coated turquoise/teal with the Akes BBK decals behind the gold DPEs!
  #7300
Old 09-25-2012, 11:31 PM
seymore4's Avatar
  #7301
Old 09-26-2012, 10:02 AM
DVG's Avatar
DVG
DVG is offline
This looks very ambitious haha
I would be damn proud of myself if I did it though. From the prices Ive seen it looks like it would be just a bit more expensive than a supercharged motor + upgraded trans + cooling for both, if I were to make it as reliable as possible.
The big thing I am trying to find out is if I can do it myself, over the course of a winter or something.
  #7302
Old 09-26-2012, 10:34 AM
SPL vs WHITELINE
your thoughts ??
anyone have an idea which would be better
  #7303
Old 09-26-2012, 10:59 AM
Max626's Avatar
I know ive seen the thread before but I can't find it, how you recalibrate the gauges?
  #7304
Old 09-26-2012, 12:04 PM
MrTBahgs's Avatar
Anyone able to comment on this for me? Thanks.
  #7305
Old 09-26-2012, 12:11 PM
TunerMax's Avatar
end links dont matter, just get moog or OEM or whatever. Just not super cheap junk cause you don't want them to break.
I always calibrate (mark) them before removing the needles.
I don't know if htere's a way to do it after you've already removed them other than trial and error.
Which gauges, 03/04 or 05/06???
Originally Posted by TunerMax
Ok, I was going to measure this but I've been swamped and I need to order these:
What size are the stock Wheel studs? I want to order 10mm larger Studs, but I don't know the stock size.....
^^Can anyone help me out here?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
