Random Little Question Thread
Old Apr 29, 2013 | 10:30 PM
  #9001
bigjee's Avatar
part number is:
96942AC501
about $11.32 here:
http://infiniti.sewellparts.com/oem-...edan-2006.html
Old Apr 30, 2013 | 12:23 AM
  #9002
G35xSam's Avatar
Awesome, thanks for the help, guys. So am I correct in assuming that I just need to pull up on the trim piece on all 4 corners to pop it up and gain access to the bulb?
Old Apr 30, 2013 | 12:55 AM
  #9003
bigjee's Avatar
yw.
Watch the first ~1min of this video (thanks to Wrathernaut)
It will get you close to changing the light bulb.
http://www.youtube.com/watch?feature...=sHRITRi_gII#!
here's a diagram to show approximate location of bulb.
http://infiniti.sewellparts.com/oem-...oupe-2006.html
Old Apr 30, 2013 | 03:51 PM
  #9004
TORETTO's Avatar
just a little notice for anyone.
cheap 2004 black sedan. 5800 obo with rebuilt motor. body looks in good condition, black interior. navi, AWD. lowered on bbs rep
if the motor is sketchy, just buy it and swap in an LS V8.
in norcal
http://sfbay.craigslist.org/sby/cto/3776359254.html
Old Apr 30, 2013 | 03:56 PM
  #9005
Plur's Avatar
That's so dam cheap. lol
Old Apr 30, 2013 | 03:58 PM
  #9006
Plur's Avatar
yo chris lets buy that thing
Old Apr 30, 2013 | 08:11 PM
  #9007
G_DiRTY5's Avatar
Lightbulb Here's a good question.
Did the horsepower actually change for '05 or did Infiniti just take advantage of the outdated SAE standard rating of horsepower? If it did change, is there dyno results to prove it? Also what did they do to increase the power?
Old Apr 30, 2013 | 09:16 PM
  #9008
herrschaft's Avatar
The revup engine was introduced in 05
Old Apr 30, 2013 | 09:27 PM
  #9009
G_DiRTY5's Avatar
But isn't revup only available for the MT sedans and coupes in 05-06? So the non-revup 05-06 models had the same power as the 03-04 models?
Old Apr 30, 2013 | 11:52 PM
  #9010
dofu's Avatar
20 Year Member
There was no real horsepower change in the non-revup motors, it was only a correction of the horsepower rating on paper.
Yes, revup is only for 05+ 6MT models and yes, all non-revup motors between 03-06 are the same.
Old May 1, 2013 | 02:52 AM
  #9011
3truman's Avatar
I think the only difference is that the 03-04 had mechanical fans and the 05-06 had electric fans.
Old May 1, 2013 | 10:21 AM
  #9012
Peoria35sedan's Avatar
The mechanical fans went away mid year 04, cars without mechanical fans have a different ecu which includes wideband O2 sensors. There is also a difference in the automatic transmissions, early cars will down shift in manual mode and later cars will stay in the selected gear. I'm sure there are subtle differences in the factory tune, imo they drive differently.
Old May 1, 2013 | 02:49 PM
  #9013
herrschaft's Avatar
^Up shift
Old May 1, 2013 | 03:10 PM
  #9014
^ no, down shift, if you have the car in 3rd in manual mode and leave from a light it will shift from 1st to 2nd to 3rd and stay in 3rd to the rev limiter. When I had my car dyno'd, it down shifted at the start of every pull, it was in mm 4th gear, it never up shifted beyond 4th. I have hit the rev limiter in 1st thru 3rd and it will not up shift unless you move the shifter.
Old May 1, 2013 | 03:12 PM
  #9015
herrschaft's Avatar
NM, I thought you previously said they will not downshift at all but I misread it.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
