Random Little Question Thread
#9661
I'm not sure about that one - rev up motors have more advanced timing so the plugs for rev up motors might be a step colder to help prevent detonation. If you are modded, one step colder is not a bad thing.
#9662
Considering buying a brand new spc camber kit front and rear from craigslist. Part numbers 72125, 72050. These part numbers are the latest version right? As a newb, anything specific I should look for when inspecting the kits (any parts not supposed to be loose etc)? Fast reply would be much appreciated, thanks
#9663
Considering buying a brand new spc camber kit front and rear from craigslist. Part numbers 72125, 72050. These part numbers are the latest version right? As a newb, anything specific I should look for when inspecting the kits? Fast reply would be much appreciated, thanks
dominate (10-13-2013)
#9664
#9665
Hey guys, new member. I just bought a 04 G35 6 speed sedan to play around with. Still not sure what direction I'm going with it. Maybe flat black, nitrous, any ideas? I'm thinking about $2K maybe 3 to put into it. I own a small shop on the side, so no labor charges. It doesn't matter about emissions either. Just looking for ideas/advice. Thanks!!
#9666
And IMO, even if you are installing everything yourself and have the capabilities to properly tune your ECU yourself, $2-3k is not a lot of mods. An exhaust can easily cost $1k, and suspension can easily cost another. If you just want more power, $3k isn't going to go very far there either - you might be able to get a good turbo kit, but you won't really have anything left for any supporting mods.
Also, I honestly would not NOS these motors unless it has been built, or at least have a spare sitting in the garage.
#9669
#9670
#9672
I agree that I need to change it. I just can't seem to find where to buy them. By any chance you guys have a part number I can work with?
#9673
Honestly, it's not necessary to replace either bolt or washer unless it's damaged or isn't working properly. It's only suggested that you change the washer as that part assures the seal, and is spring loaded.
#9675
What stock HID are in a 2004 G35 Sedan? and what type are they? D2R?
Hi, I drive a 2004 G35 Sedan, one of my low beam headlights went out and i need to replace it.. can someone please tell me what hid stock is in the car? and what kind of HID would i need? D2R? I am new to all of this.. so sorry if i sound stupid!
