Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #9721
Old 10-31-2013, 05:28 PM
G_DiRTY5's Avatar
Originally Posted by weiizy81
So I was planning on getting a z tube, do I need to get a filter with it or not, most I've found don't come with filters. Also I was going to go with stillen, but saw you could use the 350z intake and swap it on..am I correct?
Yea I was at that point once. I was gonna get the stillen z tube with stillen intake but then I read somewhere on this forum that the stillen z tube is low quality and pics were shown of the inside which had things sticking out and random holes which would cause turbulance of the air passing through the tube. I ended up going with the OEM z tube with stillen intake.
I'm sure you wouldn't notice that little tiny difference but it's something to keep in mind when buying and I'm picky.
  #9722
Old 11-05-2013, 06:19 PM
GreenPenguin's Avatar
Any tips for painting the stock grill?
  #9723
Old 11-05-2013, 06:23 PM
jeggo's Avatar
Search it here there's a thread about that with pictures.
  #9724
Old 11-05-2013, 06:24 PM
Stubie1918's Avatar
There is a DIY under tech area
GreenPenguin (11-06-2013)
  #9725
Old 11-09-2013, 06:24 PM
Lal's Avatar
Lal
Lal is offline
Random little question: I am trying to purchase a new 2006 G35x sedan. Took it to my mechanic and he said it has a problem in the exhaust system where the exhaust meets the muffler apparently it has leaking/wear I'm not completely sure. Long story short would this exhaust (Megan OE-RS catback) work on my car without having to get a new Y-pipe/other exhaust parts? The Y pipe is in good shape.
http://www.semotors.com/megan-racing...FdJj7Aod22YAFw
Thanks in advance
  #9726
Old 11-09-2013, 07:52 PM
HereKittyKitty's Avatar
Have FI high flow cats, sounds good to me. Have removed the z-tube.
  #9727
Old 11-09-2013, 07:56 PM
Lal's Avatar
Lal
Lal is offline
Are they necessary? Will my exhaust sound shitty if I don't have them? I'm on a pretty tight budget. I figured if I need to replace part of the exhaust may as well get a catback system now especially at that price.
  #9728
Old 11-09-2013, 08:00 PM
No, but it allows for a "better flow". I had the ztube on but prefer stock.
The rest of my exhaust system is fine/stock, for now.
  #9729
Old 11-09-2013, 08:39 PM
Lal's Avatar
Lal
Lal is offline
Besides wanting better flow, I should be fine using that system with all other stock parts though?
  #9730
Old 11-18-2013, 10:55 PM
X-Rated's Avatar
I live in Staten Island NY, which Plenum would u guys recommend ? 5/16" Thermal or Iso thermal ? lmk
  #9731
Old 11-19-2013, 12:06 AM
herrschaft's Avatar
^All you really need is the spacer itself
  #9732
Old 11-19-2013, 01:01 AM
dofu's Avatar
Get the iso thermal gasket that goes between the lower intake premium and the motor. The coolant bypass isn't necessary, but the gasket should help lower intake temps quite a bit.
  #9733
Old 11-19-2013, 04:22 PM
X-Rated's Avatar
Vendors are telling me to go with copper iso thermal spacer because i drive it in the winter
  #9734
Old 11-19-2013, 04:25 PM
seymore4's Avatar
Of course they are, its more expensive
  #9735
Old 11-19-2013, 04:35 PM
Rob902's Avatar
Anyone ever do a road tune before? There's no awd dynos within 1000 miles from me.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
