Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #8161
Old 01-06-2013, 03:28 PM
Shanes_G's Avatar
What type of steel are art pipes made from?
  #8162
Old 01-06-2013, 03:29 PM
DVG's Avatar
DVG
DVG is offline
Ask motordyne...
  #8163
Old 01-06-2013, 03:32 PM
Shanes_G's Avatar
Was hoping to get a quick response instead of waiting for an email. Guess ill wait then.
  #8164
Old 01-06-2013, 03:34 PM
DVG's Avatar
DVG
DVG is offline
Well I'm pretty sure every aftermarket exhaust component is stainless, but you'd have to ask them for the grade
  #8165
Old 01-06-2013, 03:36 PM
Shanes_G's Avatar
I just sent them an email, mine are cracked and my welder needs to know what grade stainless they are.
  #8166
Old 01-06-2013, 03:38 PM
DVG's Avatar
DVG
DVG is offline
Yikes, I was thinking of getting some of those. How'd they crack?
  #8167
Old 01-06-2013, 03:44 PM
Shanes_G's Avatar
The v1 crack very easily, the driver side one barely scraped when I bottomed out a bit ago and it cracks the connection to the actually tp.
  #8168
Old 01-06-2013, 04:55 PM
JDMswagSerf's Avatar
Originally Posted by The Stimulation
Yes, that's how it is for all our G's.
I can see about taking one tonight. Although I don't have the 8k's on anymore.
And yeah, the leather OEM boot is what I was referring to. But honestly, it's just my opinion. You should mod your car the way you like.
Noticed you edited your post. You can't really do what you're wanted. Your low beam functions on it's own. Your high beam and low beam are the same bulb. However, when you get an HID kit as DVG pointed out you don't want your high beam to be an HID because it will burn out the bulb very quick, thus you lose high beam capabilities by going with a bulb designed just for the fog light (it doesn't have a dual filament like the OEM bulb does). You can buy a dual filament yellow bulb (I think) but your high beams will also be yellow. You can change the bulb to blue for the high beams, but your fog flights will be blue as well and that defeats the purpose of a fog light.
yea, i understand what DVG said about not having a high beam hid because the time delay for it to warm up.
And okay, the low beam and high beam are 1 dual filament bulb, by the way i saw they looked, i thought they were 2 single filament bulbs.
bottom line,
will this hid kit
http://www.ebay.com/itm/HID-KIT-H1-H...cf06a3&vxp=mtr
work with this yellow bulb for foglights?
http://www.ebay.com/itm/H4-DT-3000K-...058f54&vxp=mtr
The reason i ask is because, they both say "lowbeam" i dont want to get both and only one work, i want it to look like yours, blue hid low beam, yellow foglight.
and H4 type bulbes for the hid and foglight right?
Thanks in advance!
  #8169
Old 01-06-2013, 05:08 PM
The Stimulation's Avatar
bottom line,
will this hid kit
Thanks in advance!
The HID kit I have is similar to what you posted, not the same brand, but same thing as what I have. Basically you'll lose functionality of your high beams but I've found the fog lights to be bright enough that I don't need high beams. And for the low beams I just upgraded my bulbs to 6k.
  #8170
Old 01-06-2013, 05:18 PM
so its okay for me to get both of those kits right? they will be compatible with eachother?
  #8171
Old 01-06-2013, 05:22 PM
You have factory HID right? If so just buy some 8k bulbs for your low beams and then the H4 HID kit you posted. Might wanna check out what the vendors here have as well. They may be the same price or better quality/warranty.
  #8172
Old 01-06-2013, 06:02 PM
I dont think so...my light beam looks like stock beam. the lights turn on right away, no delay as there would be with hid
What vendors do you speak of?
But the 2 links i posted will work together right?
like i can use the yellow bulbs as fogs and the hid kit as low beam right?
  #8173
Old 01-06-2013, 08:05 PM
DVG's Avatar
DVG
DVG is offline
Just to clarify, since you guys have mixed these up a couple times. The upper reflector is the low beam. I think some 03/04 and all 05/06 came with a hid bulb here. Sold 03/04 had halogen.
The lower reflector is the fog light/high beam. No cars came with an hid here. If you want hids here, there are 3 options: best - retrofit a bixenon projector. 2. Ok - Get a fog light hid kit 3. bad - Get a bixenon hid kit. This will give weird reflections and ****. Don't do it. With bixenon, you keep both fog light and high beam. There is only one "filament" - in hids, this is actually a plasma capsule. The dual output function is actually the result of a plate which moves up and down to change the cutoff of the light beam
TunerMax (01-06-2013)
  #8174
Old 01-06-2013, 09:09 PM
oh okay.
I am going to orders a low beam hid which will go in the top bulb area and
the yellow bulb in the low headlight area.
I was really getting confused here.
but, the yellow bulb says "lowbeam" will it fit I into the lower connector of the headlight?
  #8175
Old 01-06-2013, 09:19 PM
DVG's Avatar
DVG
DVG is offline
oh okay.
Im not sure what you mean. Here are the bulb sizes for 2003 sedans:
If you do not have OEM HIDs:
Low beam = H1
High beam / fog light = 9003/HB2
If you do have OEM HIDs:
Low beam = D2R
I dont know what year your car is. Use this to find out your bulb sizes: https://www.sylvania.com/en-us/appli...n.aspx#fldYear
A bulb is a bulb, you just have to search for bulbs that are the same size. As long as it fits the socket, it will work
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
