Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #8101
Old 01-04-2013, 04:19 AM
dominate's Avatar
Looks like data grill and work meister wheels
canehdian_guy (01-04-2013)
  #8102
Old 01-04-2013, 05:53 AM
JDMswagSerf's Avatar
I posted this in another thread but In case no one views it. I will post it here as well.
when I start my car, it warms up a bit. about 25% on the gauge then I take off.
I approach the stop sign down the block and I proceed to go and for a split second it's like the engine or transmission lag and are not responsive to the gas pedal, so I push the gas pedal down a tiny but more then the car jerks real nasty like if it finally ricieves input from the ecu and jams into gear.
it's not a huge lag like 3-4 sec. I'd say 1 sec lag then the jerk.
I do t think it's downshifting because 1. I'm going 3 mph & 2. I'm not flooring it and since its in first gear because I'm going 3 mph, it can't downshift into 0 gear!
I've seen online people say trans fluid could be it. it's AT.
has anyone had this issue and resolved it?
  #8103
Old 01-04-2013, 09:24 AM
Peoria35sedan's Avatar
Normally I'd say it's a tranny problem but with your recent battery problems and all the issues I see in your "need help" thread, who knows, that cars a mess. You might start by fixing all the damaged OE safety equipment and replacing the battery.
TunerMax (01-04-2013)
  #8104
Old 01-04-2013, 09:33 AM
Originally Posted by CleanG35x
So would the 400$ programmer even be worth buying?
No. What year is your car?
  #8105
Old 01-04-2013, 11:02 AM
Ednica87's Avatar
I know that theirs prob. a thread for suspension question but I couldn't find it, sorry. Anyways if I removed any rim or not how to tell if your G has sport strut/shocks??? 06 G sedan. thanks
Posted from G35driver.com App for Android
  #8106
Old 01-04-2013, 12:08 PM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
If your shocks/struts are red you have the sport suspension. You could also call any Infiniti dealer, give them your VIN, and they could tell you exactly what options came with the car.
  #8107
Old 01-04-2013, 12:36 PM
flexican77's Avatar
Moved from Cosworth / Motordyne Thread
probably a very noob question, but I have the skunk plenum spacer...would it be safe to say I could also get the MREV2 for my 03 g35?
  #8108
Old 01-04-2013, 01:19 PM
Mr. Samster's Avatar
do you guys know if the parking light inside the headlight is 12v or not?
  #8109
Old 01-04-2013, 01:43 PM
DVG's Avatar
DVG
DVG is offline
Every bulb is 12v...
  #8110
Old 01-04-2013, 02:12 PM
NFSP G35's Avatar
? = 2B || !2B
^Not the HID bulb! Just the input into the ballast is, the bulb itself is thousands of volts...
....ok, I'm done now. Sorry
The following 2 users liked this post by NFSP G35:
DVG (01-04-2013), TunerMax (01-04-2013)
  #8111
Old 01-04-2013, 02:30 PM
TunerMax's Avatar
  #8112
Old 01-04-2013, 03:00 PM
That is what i thought. I was doing some led work and when i tested it with my power supply all leds would work. Once i put them on the car, turn on the parking light they would work. Then i turn on the low beam one led would go out. then from there on it would switch on and off between leds. Total leds per headlight is 4.
Since that idea didnt go so well, im going a different route. Something different.
  #8113
Old 01-04-2013, 04:02 PM
Ednica87's Avatar
Thanks a lot, guess I forgot they could look that up for me.
  #8114
Old 01-04-2013, 05:54 PM
Shanes_G's Avatar
I have the 5/16 spacer, and I just got some new polished bolts for the upper plenum, can I just take the 6 bolts out of the center portion of the upper plenum without the plastic pieces inside moving out of place on me? Or should I stop being lazy and take off the upper plenum and then put them on. Asking bc it's cold as hell here and I'm trying to make this a quick project, and possibly save myself 30 min of standing out in this weather. Thanks dudes!
  #8115
Old 01-04-2013, 07:48 PM
TunerMax's Avatar
Yes you can remove the 6 bolts safely, or do them 2 at a time if you're concerned. Either will be fine
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
