Random Little Question Thread
#1041
http://my350z.com/forum/wheels-and-t...nkei-rpf1.html
that rear tire is only .3" shorter then mine, .15" of sidewall for his track setup...he must be stupid i guess(sarcasm in case the z owner should find his way over here)
#1046
#1048
#1049
the dealer installed an exedy clutch on my rsx and never adjusted the clutch pedal so it became harder and harder to get into gear, but i thought I was just being a spaz and missing second, then one day on an 8600 rpm shift to 2nd gear I ripped all the teeth off or something and when I tried to shift into 2nd after the traffic light my tranny sounded like a pinball machine...lucky I had a little warranty left so the dealer rebuilt the tranny. Then I got it back and 2nd still wasn't going in easy, so I adjusted the play on the clutch pedal and after that it went in like butter...if only I had thought of it before the tranny exploded.
Q:
I miss high revs, how hard is it to swap in a VQ35HR?
Q:
#1050
on
^Probably not easy. You would need the computer to go with the HR, and that could possibly pose a problem for you as there were other changes from 04 to 05 (or even halfway through 04) with other components that "talk" to the ECU like the transmission computer (not a problem for you obviously, just an example)
Your car still might pose less of a problem because of being a MT, but with a swap like that, there's often a ton of tiny, unforeseen problems that crop up. :/
Then again, there may not be that much to it.![Dunno](https://g35driver.com/forums/images/smilies/dunno.gif)
Maybe someone with a more complete understanding of all the differences between the two engines can chime in, if not, you might have to take that question to the tech section.
